K20 Prelude
Has anyone ever put a k20 in a 97 up prelude? i know you would be loosing displacement but the k20's seem to have much more potential. i was wondering because i will soon be doing a auto to manual swap and it sounds like a pretty resonable idea to swap in a rsx type s engine and tranny. thoughts anyone?
h22 is best you can get for a prelude.....k series would require way too much work to fit in a prelude from mounts, to axles, to shift linkeage to everything! they are just too different.....but it would be possible, but most likely not worth the trouble.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 »</TD></TR><TR><TD CLASS="quote">h22 is best you can get for a prelude.....k series would require way too much work to fit in a prelude from mounts, to axles, to shift linkeage to everything! they are just too different.....but it would be possible, but most likely not worth the trouble.</TD></TR></TABLE>
the same process that is required to swap the engine into any other car that was not originally equiped with a k-series. the main problem with that swap at the moment is that there is no company that i have heard of that is producing any mounts, if you have the capacity to build your own then that shouldnt be a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">::smacks you all::
Where the **** is your H-series pride?
hahaha,
hahaha,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 »</TD></TR><TR><TD CLASS="quote">k24 bottom end with what h22 head? good luck with that one.....</TD></TR></TABLE>
dude are you retarded or somthing, hes saying a k24 block with a k20 head
its sounds like a good idea, a good amount of work is needed to put that head on that block, its nowhere as easy as b series
and by the time you spend all that money in your car, it will not be much faster and youl be out of cash, just spend that cash on the h22 in the car and your car will be much much faster and not hacked up
k20 will have the bling factor and bragging rights, but its not worth the cash to do it right
plus like mentioned before, there are no mounts available for this motor into a lude, so the mounts will need to be custom, and thats not high cash for that, premade mounts are only out for eg/ek/dc so far
well maybe he doesnt know that, and your wrong theres lots of heads...
k20a2
k20a3
k24
k20a....
obviously he doesnt really know that much if hes asking if it would be benificial to put a k series in a lude...
k20a2
k20a3
k24
k20a....
i was thinking of using a head off a type s, the only reason i am considering this is because im want to rebuild my motor to run more boost and its not cheap to get it resleeved. also i want to to a auto to manual swap. other than custom motor mounts and drive shafts it shouldnt be any different than putting a k20 in anything else. plus the prelude has more room under the hood. this isnt my daily driver and i know this would take alot of time and custom fabrication but i think it would be worth it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos »</TD></TR><TR><TD CLASS="quote">In case you haven't heard there is a H22a block with k20a2 head motor that made around 330whp all motor. lol I am being serious</TD></TR></TABLE>
got a link or something ro where i could find this?
wtf?????
wtf?????
17:1 compression 2.3 L
It was posted here on honda tech by the 2004 All motor NDRA champion Mark Brauning
Pro Stock
Champion – Mark Brauning, Honda Civic
http://ndra.nopi.com/ndra_2k4/...d=248
he won the title with a h22a setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabworxs »</TD></TR><TR><TD CLASS="quote">H22 short block w/ K20 head...smell like BS. I'll believe it when I SEE it with my own two eyes!</TD></TR></TABLE>
No prob. I have not seen it either. However, if someone can test fit a type s head with a h22a block that would confirm the fitment. I was told, it fits.
tard
