Coolant Flush Step-by-step?
Hello lude dudes. I want to know how to flush the coolant. I am kinna newb at maintaining my car i just do engine changes, spark plug change, and tranny changes myself so if someone can provide me pictures of where the drain bolt is and filler plug or a description of how to flush the coolant and fill you would make my day
happy.
happy.
how in the world do you know how to change a tranny but don't even know where the drain plug is. sounds like you are just throwing bs and don't know how. i bet your probably looking up how to change your 710 fluid too
if by coolant you mean the radiator then there should be a small round plug at eh bottom of the radiator that you can see if you get under the front of the car.
You just need a phillips screwdriver to undo it and all the old liquid will come flying out.
make sure its cold before you do it and undo the cap at the top of the radiator first before doing this.
you can just pull your water tank out and empty it and wash it to get rid of all the dirt at the bottom then fill it up fresh and add anti-freeze/summer coolant..
make sure you put about 2 and a half litres of water into the radiator once you close the plug at the bottom.
hope this helps
hope this helps
dk127
Apr 24, 2007 09:01 AM
camera obscura
Jul 13, 2004 06:04 PM
