Yep it's my taillight, it's leaking TONS of water
Old Jan 4, 2005 | 06:20 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Yep it's my taillight, it's leaking TONS of water
So tonight I filled up my bathtub and dunked the taillight into the water, inside side down. I did this so that there would be some air trapped inside and I could see look for bubbles escaping to see where water was coming in.
So I did that and TONS of bubbles poured out from the upper edge of the lens, right below where the hatch closes on top of it. That's where water is getting into the taillight, fills it up, and subsequently spills over into the car.
So if you remember my thread where I added weather stripping around the taillights, DON'T DO THAT! It makes more water run down over that top edge of the taillight lens and if your taillights are leaking there, it will let more water into the taillight. If you have ever taken the taillight off and found the bottom inside edge of the gasket all wet or very dirty, then your taillight is leaking, and could very well be coming in at that top edge.
Here was my thread I made about what I thought was a solution, but was actually a failure. https://honda-tech.com/zerothread?id=1086869
So now I need to replace the taillight. I don't think I can simply seal it, because any sealant would be VERY visible from the outside. Anybody have a driver side 94-97 taillight sitting around I could get from you?
Modified by PatrickGSR94 at 9:30 PM 1/4/2005
Old Jan 4, 2005 | 06:59 PM
F.U.D.'s Avatar
glad you got it figured out mang
Old Jan 4, 2005 | 07:07 PM
Racermech's Avatar
Default Re: (F.U.D.)
What about getting some CA glue from a hobby shop and trying to seal it back up?
Old Jan 4, 2005 | 07:16 PM
dFreezy's Avatar
Default Re: (Racermech)
congrats on finding the culprit
i know i've seen several 94-97 tail lights in the classifieds recently, i can't remember the exact threads tho
Old Jan 4, 2005 | 07:55 PM
xprohx's Avatar
I think too much
Default Re: (dFreezy)
The foam gaskets for the taillights being a little wet around the edges is fine. Mines was like that when I checked and there is no water in the hatch.
Are you thinking about upgrading to 98-01 tails now? Or maybe the jdm 98-01 tails?
Old Jan 5, 2005 | 03:10 AM
Community Builder
Default Re: (xprohx)
No I prefer the amber turn signals on the teal color.
If the gasket is wet or very dirty (or both) all along the bottom edge such that it looks different from the rest of the gasket, the taillight is definitely leaking in water.
Old Jan 5, 2005 | 06:14 AM
juicy.fn's Avatar
Default Re: (PatrickGSR94)
well im glad you found the problem! nomore headaches, hopefully! but WE NEED TO FIND THIS MAN A TAILLIGHT lol ill look around for ya. my cousin works for honda, maybe they have one sitting around. ill ask him
Old Jan 5, 2005 | 10:07 AM
ATS*JONES's Avatar
good to hear you found the problem...
Old Jan 5, 2005 | 10:46 AM
Marauder's Avatar
Default Re: (Da6rEpLiCaToR)
Hope that finally fixes it for you! Once I get my teg back from my friend I have to fix the water leak in it. I think its just the sunroof drains, but he's had the car for over a month so I haven't had a chance to look at it.
Old Jan 5, 2005 | 11:05 AM
slowww b18b1's Avatar
Default Re: (Marauder)
i have a 94-97 driver side (left) taillight, just pm me.
Old Jan 5, 2005 | 11:10 AM
GsrJasonIII's Avatar
Default Re: (slowww b18b1)
I have both for you, there 99 perfect condition.
jason
Old Jan 13, 2005 | 12:21 AM
BETNCORT's Avatar
Default Re: (GsrJasonIII)
Ya i just got a 96 GSR and i have the exact same problem. My driver side tail light has condensation in it and i also have a little bit of water in my trunk when it rains or snows. I constantly dry it but i am not sure where it is coming from. I suspect its coming from the driver side tailight because of the visible drips in it.
Would i have to replace my tail light?
dlenoxx
Dec 2, 2010 12:05 PM
kixcrx
Dec 11, 2007 03:57 AM
idriveadelsol7
Audio / Security / Video
Apr 10, 2006 12:30 AM
Speed 101
Jan 28, 2006 06:44 PM
lonefuzzy79
Sep 30, 2002 02:54 PM
