S model Calipers the same as Vtec model?
Old Jan 4, 2005 | 05:27 PM
mattmw88's Avatar
Default S model Calipers the same as Vtec model?
I need to get a new caliper so I was wondering if I would be able to use anyother calipers besides those from S model ludes. Let me know as I found both rear calipers w/ abs sensors(not going to hook them up) from a vtec model. Thanks a lot for your help,
Matt
Old Jan 4, 2005 | 05:39 PM
PirateMcFred's Avatar
Default Re: S model Calipers the same as Vtec model? (mattmw88)
I think that the Lude's rear calipers are all the same but the S model's front calipers are not. But the VTEC front calipers should bolt right up. Just be sure to swap to the larger VTEC rotors too.
Pirate
Old Jan 4, 2005 | 05:42 PM
mattmw88's Avatar
Default Re: S model Calipers the same as Vtec model? (PirateMcFred)
I know that the fronts will bolt up, as I already did the swap. The rears are what I am concerned about now. I was wondering if the calipers would fit, or If the calipers and rotors would be needed, or if it is not a bolt up setup when switching from S model prelude rear calipers, to those of a Vtec model.
Sorry I didn't specify...
Old Jan 4, 2005 | 06:08 PM
Dougs96SI's Avatar
A little off the topic, but, do the vtec calipers have more stopping power than the H23 calipers?
Old Jan 4, 2005 | 07:28 PM
mattmw88's Avatar
Default Re: S model Calipers the same as Vtec model? (Dougs96SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">A little off the topic, but, do the vtec calipers have more stopping power than the H23 calipers?</TD></TR></TABLE>
the front rotors for the vtec model are larger, therefore stop the car a little quicker (more braking surface).
Back to my question, are they the same???
TIA
Old Jan 4, 2005 | 07:48 PM
2lude4u's Avatar
The rear calipers are the same for S, SI, and Vtec models, except for the ABS sensor. They all use the same rotor, so you don't need to change a thing.
Old Jan 4, 2005 | 08:56 PM
Sorry, I should have read your sig. But I still have heard that the calipers are the same. You might be able to check the part number here http://www.slhondaparts.com
Pirate
darockstar
Nov 14, 2008 08:06 AM
TylerC161
Aug 19, 2007 03:09 PM
93sivtec
Jan 12, 2007 09:20 AM
jomama
Nov 14, 2006 06:04 PM
Em0ne
Apr 27, 2004 07:58 PM
