Clutch Disc fit?
Old Jan 4, 2005 | 04:13 PM
VIS250P's Avatar
Default Clutch Disc fit?
Im gonna use ACT street disc on the Type R Pressure Plate.. Do anyone had experience use different brand disc on Type R Pressure Plate? If yes or no, give me comment? Thanks...
Old Jan 4, 2005 | 06:11 PM
arw321's Avatar
Default Re: Clutch Disc fit? (py)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py &raquo;</TD></TR><TR><TD CLASS="quote">Im gonna use ACT street disc on the Type R Pressure Plate.. Do anyone had experience use different brand disc on Type R Pressure Plate? If yes or no, give me comment? Thanks...</TD></TR></TABLE>
I use an Exedy organic disc w/ITR pressure plate and I have no problems.
HTH.
Old Jan 4, 2005 | 07:33 PM
VIS250P's Avatar
Default Re: Clutch Disc fit? (arw321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 &raquo;</TD></TR><TR><TD CLASS="quote">
HTH.
Thank, I need more feedback because other guy say the performance disc could worn out the factory ITR pressure plate because the OEM material are not made for performance.. I wait and see 100% feedback of they use aftermarket disc on OEM pressure plate.. I will get it..
Old Jan 7, 2005 | 05:48 PM
ACTman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py &raquo;</TD></TR><TR><TD CLASS="quote">Thank, I need more feedback because other guy say the performance disc could worn out the factory ITR pressure plate because the OEM material are not made for performance.. I wait and see 100% feedback of they use aftermarket disc on OEM pressure plate.. I will get it.. </TD></TR></TABLE>
You need to use an ACT pressure plate and flywheel too. I think you need to get the bearings and alignment tool from us as well or it might not work... Just give me your credit card number or a blank check and I will "hook you up"...
Just kidding. The material will not eat into the pressure plate. It is fully compatability, and will increase rpm tolerance and durability, but it won't handle more torque running just our disc.
vti2
Jan 3, 2007 03:49 AM
cbmprelude
May 23, 2006 02:48 PM
DX Hybridizer
Jun 7, 2005 08:46 PM
StreetwizeRacin2
11
Mar 30, 2004 03:53 PM
HONDABROMANDUDE
Apr 26, 2003 02:16 PM
