H22 distributor question?
i think my dist is bad on my h22. the problem is it has an internal coil along with there plugs. i have a external coil distributor, can i wire it in, has any one done this. please help, this would save me alot of $
thanks
shane
thanks
shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaZvic »</TD></TR><TR><TD CLASS="quote">EXTERNAL IGNITION COIL will have 3 wires coming out of it. 2 connect to the distributor and 1 goes to a power source.:
GRN@coil, GRN@dizzy - connects coil to dizzy
YEL@coil, BLK/YEL@dizzy- connects coil to dizzy (should be a LARGE wire)
BLK/YEL - connects coil to power source.
I did just that. In the final stages of my swap I realized a crucial thing was overlooked. I could not get my hands on the wiring harness for the clutch saftey circuit. My accord was an automatic to begin with so I converted it over to manual, and did not have the dash wiring for the clutch saftey switches. I had an MSD kit from the original motor that I wired up instead. I pulled the internal coil, and wired the msd blaster coil in it's place. Then hooked it all up to the MSD 6A module. It works great. Are you sure the dist is bad? Maybe it's just the coil. Let me know if this would be helpful info for you.
AmonDin
Feb 14, 2005 07:02 PM
its offo of a 98
