how to fix the hoop opener?
Old Jan 4, 2005 | 03:20 PM
Mackenzie's Avatar
Default how to fix the hoop opener?
it seems not to be pulling far enough, and if i close it i cant get it open from the inside of the car (or popping it up). how would i get it to open?
Old Jan 4, 2005 | 03:26 PM
Lil Red CRXsi's Avatar
Default Re: how to fix the hoop opener? (Mackenzie)
First I would go to a Honda dealer and order a new hood cable for your car.
Old Jan 4, 2005 | 03:27 PM
IO_303's Avatar
mine didthat for a while, and if you grease it up it should work fine
Old Jan 4, 2005 | 03:31 PM
bucketheadCRX's Avatar
sounds like the latch cable is stretched(or the cable pulled through the back side of the latch)..you'll need a friend to help and a pair of pliers..(1)get the friend to help press up/down on the hood as you (2)grab the end of the cable(the end of the cable is secured behind the "latch lever"..you can slide the "ball end" of the cable out from behind the lever..youll see what i mean after you climb under there)and tug as your friend pushes up/down to make the hood "pop"./stretched hood latch cables are apparently a common problem with crx's..i know mine has been bad for awhile and ive used pliers for years good luck/hope this helped a little
Old Jan 4, 2005 | 03:34 PM
Default Re: how to fix the hoop opener? (buckethead36)
EDIT:forgot to add....make sure the cable is still secured inside that "hood lever"mechanism..whatever the hell it's called so that pulling the wire with the pliers will "pop" the hood
Old Jan 4, 2005 | 04:15 PM
Mackenzie's Avatar
ill try a different wire i picked up at the junkyard.
cbags05
12
Aug 30, 2014 05:36 PM
AlexRex91
Apr 15, 2013 07:52 AM
hurnyak
Aug 15, 2010 08:30 AM
brcivic411
Mar 4, 2006 02:51 PM
sinfultrends
Dec 29, 2005 11:51 PM
