looking for a shop to drill out a screw...*SOCAL*
Old Jan 4, 2005 | 02:41 PM
Unjockable's Avatar
New User
Default looking for a shop to drill out a screw...*SOCAL*
willing to drive anywhere but prefer OC. i have a small screw stuck in the tranny where my shift linkage normally screws in. i can't drill in it so i can't use the screw extractor. tried titanium drill bits and cobalt drill bits but no luck. so i basically need someone to do drill it or do something to get it out.
anyone know anywhere that will do it?
Old Jan 4, 2005 | 03:28 PM
JapJunkie's Avatar
Default Re: looking for a shop to drill out a screw...*SOCAL* (Unjockable)
Got pics?
Old Jan 4, 2005 | 03:39 PM
Unjockable's Avatar
New User
Default Re: looking for a shop to drill out a screw...*SOCAL* (JapJunkie)
sorry, no pics but i can try and get some. any help?
Old Jan 4, 2005 | 03:42 PM
Marauder's Avatar
Do you have a screw in the location where the "bitch pin" should be?
Old Jan 4, 2005 | 03:43 PM
Unjockable's Avatar
New User
Default Re: looking for a shop to drill out a screw...*SOCAL* (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a screw in the location where the "bitch pin" should be?</TD></TR></TABLE>
no, it's the other part of the shift linkage. the part that connects to the tranny.
Old Jan 4, 2005 | 03:59 PM
allmotorEG-SI's Avatar
try AAMCO, they are a tranny shop. they might be able to help, i don't think you need any kinda specialty shop for this.
Old Jan 4, 2005 | 04:29 PM
Unjockable's Avatar
New User
Default Re: (allmotorEG-SI)
the problem is not the tranny though. it's the bolt stuck in it. but i'll give it a try. anyone else with suggestions?
Old Jan 4, 2005 | 04:37 PM
Civicse's Avatar
Default Re: (Unjockable)
try a carbide drill bit. carefull their very brittle so if u snag it on n e thing while drilling u'll break it. and r u just using a hand drill? or u could try kinda tapping a punch or something pointy on the side of the bolt and try and coax it out. unless its really tight then never mind.
Old Jan 4, 2005 | 04:48 PM
Unjockable's Avatar
New User
Default Re: (Civicse)
i doubt a corbide will help me. i tried the cobalt which is meant for heavy metal. i'm using one of these...(but mikita)
Old Jan 4, 2005 | 06:03 PM
Civicse's Avatar
if its really that stubborn then ur prolly gonna need some more power to break through it like a radial drill, so unless u have like 20 or 30 grand lyin around for one a shop would b a good place to take it to. and i don't c y carbide wouldn't help. i use it all the time at work, actually i use high speed steel to drill through hardened bolts. try a drill bit with a flater angle, i'm guessing ur's r 118 included angle. try a 135, they work better for harder materials. sharpen it urself or buy one. and post some pics if u can so i can c what ur talken about and maybe b more help
Old Jan 4, 2005 | 06:07 PM
Luserkid's Avatar
Try Jim at Jim's Tap Extractor, his in Gardena.
310.324.4446
He does very good work, and not that expensive either.
Old Jan 4, 2005 | 09:23 PM
Unjockable's Avatar
New User
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Try Jim at Jim's Tap Extractor, his in Gardena.
310.324.4446
He does very good work, and not that expensive either. </TD></TR></TABLE>
thanks! think he'll charge me more since it's under the car? i really don't want to pull out the tranny since i just swaped the motor in a couple days ago.
Old Jan 4, 2005 | 09:25 PM
Luserkid's Avatar
Oh i think youll have to bring him only the tranny. He doesnt really have mechanic tools, only machine shop stuff. Its a machine shop.
thundernutz
Sep 27, 2009 04:22 AM
EJ6SON
Jun 19, 2008 10:07 AM
The Flying Dutchmen
Nov 14, 2006 12:34 PM
loosestool
Sep 11, 2006 09:59 PM
stegon78
Jun 24, 2005 08:46 AM
