97 Accord EX 2.2l -eratic cold idle.....
Old Jan 8, 2002 | 10:33 AM
GSR-REX's Avatar
New User
Default 97 Accord EX 2.2l -eratic cold idle.....
My wife's 97 Accord just started having idle issues. In the morning or at a cold start, the idle bounces between 1100-1500 and will continue to do so until the car is either warm or in gear.
Any Ideas? I did a search but did not find anything relating to this model/year of our accord.
Any help is greatly appreciated.
Thanks in advance....
Old Jan 9, 2002 | 07:11 AM
GSR-REX's Avatar
New User
Default Re: 97 Accord EX 2.2l -eratic cold idle..... (GSR-REX)
Can't anybody help?
Thanks in advance.....
Old Jan 9, 2002 | 07:49 AM
BigBlockCRX's Avatar
New User
its probably the fast idle control valve.. same thing with my wifes prelude 2.3.. it did this for like 3 months and I replaced almost everything until my buddy told me about the fast idle thing..
its underneath your throttle body and what it does is takes your coolant and samples whether it is cold or hot.. when cold, it'll tell the throttle body to let a little more air in to raise the idle, and when warm does the opposite.
you gotta get the part from honda.. its about a 100 bucks I think.. if you have a buddy that works at a dealership let him get it, it'll be cheaper.. only takes about 20 min to replace and you should be ok
good luck
charles
Old Jan 9, 2002 | 08:47 AM
urbanlegend21's Avatar
New User
Default Re: 97 Accord EX 2.2l -eratic cold idle..... (BigBlockCRX)
http://www.hondaautomotiveparts.com/...=THROTTLE+BODY
look at #14
this is your fast idle control valve
Old Jan 10, 2002 | 09:42 AM
GSR-REX's Avatar
New User
Default Re: 97 Accord EX 2.2l -eratic cold idle..... (urbanlegend21)
Excellent information...Thanks alot! I'll try this out tonight.
Layta
Old Jan 10, 2002 | 10:18 AM
4doorH22's Avatar
Hmmm, can this be fixed without replacement of the FICV?
Old Jan 10, 2002 | 12:44 PM
John's Avatar
New User
Default Re: 97 Accord EX 2.2l -eratic cold idle..... (4doorH22)
according to my Helms:
when cold fast idle out of spec (1000-2000rpm) you should first:
check fast idle thermo valve
then the idle air control valve
then the idle adjusting screw
but when warm rpm too high
you should first check the idle air control valve
then the fast idle thermo valve
my car has a fluttering idle when my motor is warm, so i wonder if mine is the idle air control valve... my car does not have a fluttering idle when the motor is cold... hmmmm....
[Modified by DunReit, 4:44 PM 1/10/2002]
Old Jan 10, 2002 | 12:55 PM
John's Avatar
New User
Default Re: 97 Accord EX 2.2l -eratic cold idle..... (DunReit)
hey GSR-REX, does the Accord have a code 14 error? mine doesn't...
Old Jan 10, 2002 | 05:56 PM
New User
GSR-REX- your fast idle control valve is bad or stuck closed
it is #14 on this diagram located right below where the throttle body and intake tube meet http://www.hondaautomotiveparts.com/...=THROTTLE+BODY
Dunreit-sounds like your fast idle thermo valve is fine because that is used to help the car warm up, you might need to adjust your idle speed
[Modified by urbanlegend21, 10:07 PM 1/10/2002]
[Modified by urbanlegend21, 10:08 PM 1/10/2002]
Old Jan 10, 2002 | 07:47 PM
John's Avatar
New User
even though it flutters when i idle at a stop light and my car is warm? does it just mean i need to adjust the idle speed or is there something serious wrong with my IAC?
Old Jan 11, 2002 | 03:43 AM
New User
depends on if adjusting the idle speed cures the problem or not
does your car throw a code 14?
do you have a helms manual?
Old Jan 11, 2002 | 06:26 AM
John's Avatar
New User
i'll try tomorrow, but there is no code at all... yes i have a Helms, but i'm still getting used to reading it... ifyaknowwhatimean...
Old Jan 11, 2002 | 06:31 AM
New User
yeah, that is where I am pulling most of my info from
Old Jan 11, 2002 | 06:41 AM
4doorH22's Avatar
Ummm, could the ECU be giving a code 14 without the CEL being on?
Old Jan 11, 2002 | 06:44 AM
New User
possible but not likely, you could try to run the code check anyway i guess, what would it hurt?
haev you tried resetting your ecu?
Old Jan 12, 2002 | 04:16 PM
John's Avatar
New User
i think i figured it out kids... it's probably the alternator... when i shut off all the electrical load, the fluttering idle will disappear after about 45 seconds...
however, in order for me to do the tests indicated by Helms 11-78, i need a test harness... where do you recommend i go about procuring one?
Old Jan 13, 2002 | 10:31 AM
New User
have you checked the connections on the altenator to make sure they have corroded or are loose?
Old Jan 13, 2002 | 10:38 AM
John's Avatar
New User
i'm about to look... how long to Accord alternators usually last BTW?
Old Jan 13, 2002 | 11:53 AM
LoudAccord's Avatar
also check the vacuume hoses, that was my problem and I fixed it in 2 min.
Old Jan 15, 2002 | 01:09 PM
GSR-REX's Avatar
New User
Or could it have something to do with a bad battery...cause mine died this morning!
How do I check the code on the CEL? Don't I have to jump some pins on the ECU or something?
Great info guys...I really appreciate it!
Rex
Old Jan 16, 2002 | 08:56 AM
New User
ttt
Old Jan 16, 2002 | 09:50 AM
smokin rubber's Avatar
I had a intermitent warm idle problem last winter.
Old Jan 17, 2002 | 08:36 AM
New User
Default Re: 97 Accord EX 2.2l -eratic cold idle..... (smokin rubber)
the jumper plug is underneath the glove box
use this to help: http://www.eastcoastdelsol.com/columns/view.php?id=9
Old Jan 18, 2002 | 03:41 AM
New User
ttt, so the actual technical questions don't get lost
Old Jan 19, 2002 | 09:18 AM
John's Avatar
New User
so about this test harness, what do i need for it? i need to check the ALT-FR signal...
