no clutch pedal pressure?????
Old Jan 4, 2005 | 01:20 PM
98 blacksh's Avatar
Default no clutch pedal pressure?????
i was changing my fluid from dot 3 to dot4 and now i cannot get any pedal pressure, its a solid flow of fluid out of bleeder screw, but no pressure i think all the air is out of the line , at least i cant get anymore out, but absolutely no pedal pressure
any help greatly appreciated
thanks
Old Jan 4, 2005 | 02:40 PM
prelude1897's Avatar
Default Re: no clutch pedal pressure????? (98 blacksh)
May need to get a new master and slave cyclinder
Old Jan 4, 2005 | 11:51 PM
PrettyLude's Avatar
Default Re: no clutch pedal pressure????? (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">May need to get a new master and slave cyclinder</TD></TR></TABLE>
Old Jan 5, 2005 | 12:08 AM
OzWolfbane's Avatar
if it was alright before than it could be something else...try bleeding it....
when it happened to me my slave cylinder was farked...replaced both
Old Jan 5, 2005 | 07:39 AM
prelude_1's Avatar
check ur slave cylinder and or else is ur clucth totally out of pressure..........maybe ur clucth is dead
Old Jan 5, 2005 | 07:59 AM
BrokeLude's Avatar
Sounds like the blind leading the blind.
First off, what exact procedure are you using? It should be:
1- Make sure the fluid reservoir is full throughout the whole procedure
2- Depress clutch pedal
3- Open bleeder valve
4- Close bleeder valve
5- Release clutch pedal, and pull to top if necessary
6- Repeat until all air is removed.
Remember that if there is air in the top, like from a totally empty system after draining all the fluid, the system only moves it a couple inches at a time, so it's gonna take more than a cycle or two to do it. Also, it helps to get a small clear hose and attach to the bleeder valve, then dip into a bottle of fluid. That's keeps air from getting in from the bottom if your technique isn't perfect.
Old Jan 5, 2005 | 08:49 AM
smitherton's Avatar
Default Re: no clutch pedal pressure????? (BrokeLude)
do what brokelude said same thing hapened to me. Its a 2 person job so grab a friend and you may need to open and close bleeder valve 5-6 times.....at least thats how long it took mine to finally release all the air. good luck
Old Jan 5, 2005 | 11:07 PM
98 blacksh's Avatar
Default Re: no clutch pedal pressure????? (smitherton)
i found out that i needed a new master cylinder, and replaced that and it works good, i have pedal pressure but not enough or not as much as before, it releases literally an inch or less off the floor and then the rest of the pedal is dead, any suggestions on how to get it to to release a little bit further out on the pedal and how to get more pressure , i have bled the system many many times there might still be air in the line but i highly doubt it
thanks
Old Jan 5, 2005 | 11:26 PM
PrettyLude's Avatar
did u bench bleed it?
Old Jan 6, 2005 | 10:07 AM
98 blacksh's Avatar
Default Re: (PrettyLude)
no
Old Jan 6, 2005 | 10:15 AM
Default Re: (98 blacksh)
You'll need to bleed the system again, and if you'll still not getting enough pressure, you'll probably need to change out the slave cyclinder
Old Jan 6, 2005 | 10:31 AM
98 blacksh's Avatar
Default Re: (prelude1897)
i dont know symptoms of a slave cylinder not working but it seems to be working fine right now, i have pressure but not as much as before , it is driveable but kind of annoying, also after a while it doesnt go into gear as easily, which makes me think that the pressure is lowering or something????
Old Jan 6, 2005 | 10:51 AM
BrokeLude's Avatar
You need to keep bleeding it most likely. When you get air in there, especially at the top, it takes quite a few times to get it out. If you let air get in either by letting the reservoir go dry while you bleed or allow air back in through the bleeder valve, you create a vicious circle that will never end. Follow my directions exactly and you will be fine. Put a hose on the valve and dump it in a bottle of fluid if you are having trouble.
How did you determine that the master was bad?
Old Jan 6, 2005 | 01:59 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeLude &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the blind leading the blind.
Remember that if there is air in the top, like from a totally empty system after draining all the fluid, the system only moves it a couple inches at a time, so it's gonna take more than a cycle or two to do it. Also, it helps to get a small clear hose and attach to the bleeder valve, then dip into a bottle of fluid. That's keeps air from getting in from the bottom if your technique isn't perfect.</TD></TR></TABLE>
Follow this man's advice.
And use the damn bleeder bottle! TRUST ME, it makes it much quicker and easier.
Old Jan 6, 2005 | 02:11 PM
BrokeLude's Avatar
Default Re: no clutch pedal pressure????? (LudeyKrus)
Damn, my proofreading sucks. WTF does "that's keeps" mean??? heh
Old Jan 10, 2005 | 03:45 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 blacksh &raquo;</TD></TR><TR><TD CLASS="quote"> it releases literally an inch or less off the floor and then the rest of the pedal is dead, any suggestions on how to get it to to release a little bit further out on the pedal and how to get more pressure </TD></TR></TABLE>
you could adjust the rod that goes from the pedal to the slave clynder under the dash, and pick up some slack.. usually you only do this if your trying to get the last bit of life out of the clutch... sounds like to me, your gunna need a clutch soon. the reason your pushing in that pedal soo far, is the pressure plate is a little worn.
thegatekeeper14
Jan 7, 2010 09:48 AM
Mr.Luder
May 24, 2006 08:41 PM
matto2413
Jul 16, 2005 07:08 PM
92LudeSI
Jul 13, 2005 08:23 AM
DOHCon15s
Dec 19, 2003 06:46 AM
