Revs acting funny at idle - running way rich
Old Jan 4, 2005 | 01:02 PM
Wilky's Avatar
Default Revs acting funny at idle - running way rich
I have recently installed a skunk2 intake manifold and ctr cams on my 99 civic si. Since installing, I have had issues with the revs acting strange at idle - anytime I push the clutch in, the revs drop to like 200. Sitting at a light, the revs will be okay for a moment then start bouncing between 500 and 1200 rpms. Gears are set to zero.
Anyone else ever have this problem? I am at my wit's end with this thing. It is frustrating to drive.
Old Jan 4, 2005 | 03:46 PM
Wilky's Avatar
Default Re: Revs acting funny at idle - running way rich (Wilky)
bump - help?
Old Jan 4, 2005 | 07:02 PM
Reason's Avatar
Sounds like you have a vaccuum leak. Its probably the IM gasket.
Old Jan 4, 2005 | 08:00 PM
zman's Avatar
Default Re: Revs acting funny at idle - running way rich (Reason)
i had/have the same problem after my cam/spring install. I replaced my o2 sensor b/c i got a code 41 and it helped quite a bit. It still does it once in a while, so it leads me to believe that its a vacuum leak...time to get out the old carb cleaner and start sprayin on all the vacuum lines and at all the gaskets.
Old Jan 5, 2005 | 09:03 AM
Wilky's Avatar
Default Re: Revs acting funny at idle - running way rich (zman)
Thanks. I'll be doing some carb cleaner sprayin' today. Would this be causing the rich condition on startup. I figure more air would = leaner mixture. Does it confuse the map into running rich for safety or something?
Old Jan 5, 2005 | 02:35 PM
civicdx1's Avatar
my does the same but my give me a code14.
Old Jan 7, 2005 | 08:43 AM
Wilky's Avatar
I have the ANR heatshield gasket. Anyone else have problems with vaccuum leaks with these gaksets?
Old Jan 7, 2005 | 10:43 AM
c0nspire's Avatar
Set the idle with the EACV disconnected as per the Honda service manual.
Old Jan 22, 2005 | 07:29 PM
2kEM1ebp's Avatar
Default Re: (c0nspire)
I am having the same problem after my cam install, mine dosnt just drop to 200 it dies eventually. I didnt do intake manifold, jsut cams...I could use the help too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0nspire &raquo;</TD></TR><TR><TD CLASS="quote">Set the idle with the EACV disconnected as per the Honda service manual.</TD></TR></TABLE>
How do you do this can someone explain im still learing the honda motor.
Ryan
Old Jan 25, 2005 | 09:13 AM
FuriousGeorge's Avatar
Default Re: (95b18teg)
I am having the same problem. but I didnt swap a god damn thing. no codes when read. It idles fine if I bring the car to a stop and then let off the throttle, but when I take my foot off the gas and depress the clutch the revs drop too low. I can smell the fuel I am running so rich.
I am changing cap and rotor tonight, and cleaning the **** out of the IACV and TB with cleaner. I also heard that a bubble could get stuck in the IACV cooland passages and **** idel up. Is this true?
F-in pisses me off
Old Jan 26, 2005 | 11:34 AM
Wilky's Avatar
Default Re: (FuriousGeorge)
Yep,
You guys both have the same problem as I. Car dies after sitting at a stop with clutch depressed or in neutral while engine is warm. Still haven't figured it out. How do I remove the EAVC (or whatever you have to remove to set idle)?
Help, and keep this thread going.
Old Jan 26, 2005 | 08:20 PM
SOHCex20's Avatar
Default Re: (Wilky)
I have a 99 ex and just installed a skunk2 p28, and ever since my idle has been all over the place. Sitting at a stop light it jumps from 650-900 rpm, while gradually increasing rpm in neutral sounds as if its backfiring. I've been told skunk2 p28 results in a rich running condition, but even messing with my idle air screw, iacv cleaned, and messing around with different dist. timing's, nothing has changed. I don't currently have a VAFC......would this help somewhat with smoothening the mixture out???
PROJECT 91
Sep 25, 2009 11:18 AM
Concept Tuning
Apr 28, 2006 08:28 PM
Out of every "game"
Feb 8, 2006 01:12 PM
allmotaEM1
May 19, 2005 09:59 AM
