FS: Fully Built LS engine complete, And more (parting out race car)
I have for sale a complete LS engine that I have just built and has never even been started since rebuild
I also have other parts for my LS such as:
LS tranny w/ quaife diff. and ACT xtreme clutch and flywheel
Turbo kit w/sc61 SFP mani, huge FMIC, and tial BOV and wastegate,
Haltech E6X with Crane ignition and prewired distributor for LS
Complete fuel system, pump, FPR, fuel cell, and all the plumbing.
NOTE: These will be sold after the engine has sold but if you send me a PM saying you want it I will put
you on the list for it and let you know when its for sale
-Block
- newer b18b block W/ darton sleeves
sleeved by ERL w/ step deck, 81.5mm bore, has been line bored .010 over
- Manley Turbo Tuff Rods
- Ross Pistons (9.2:1)
- Z10 Main girdle
- Arp main and head studs
- GSR oil pump
- GSR pan
- ACL main bearings
- Coated ACL rod bearings
- All machine work done by Stewart Engines
had wrist pin fit on rods and pistons to .001 clearance, bored and honed to piston to wall clearnce of .007, and main bearing and rod bearing clearances are .0017 for mains and rods +or- .0001
-Head
- 91 LS head ported out on exhaust and intake side.
- Ferrea 1mm oversized valves ex. and in.
-Crower stage 3 cams I believe, could be stage 2
-Crower Hi Press. springs (these are not the regular ones Crower sells for LS engines they are higher pressure race spring)
-Crower Titanium retainers
-Edlebrock intake w/ stock ls TB
note: not all parts are new. New parts include block, pistons, rods, bearings, timing belt, crower springs, and 4 valves
This motor is very well built, and is capable of handling over 600hp. This engine would be the perfect addition for someone wanting to make lots of power and have good reliability.
Im sure Im missing alot of minor things but PM me to find out whatever you wish to know.
Asking $4250 for complete engine
Edit: ok now I got some pics and was able to get them hosted.
I also have a b20 valve cover for it thats not shown an I am not quite done assembling the engine but it will be done very soon.
Modified by 30psi Teg at 10:04 AM 1/7/2005
Modified by 30psi Teg at 12:03 PM 1/11/2005
-Block
- Z10 Main girdle
- GSR oil pump
- GSR pan
- ACL main bearings
-Head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow90hatch »</TD></TR><TR><TD CLASS="quote">only if i had 5000 grand </TD></TR></TABLE>
then you'd have 5 million dollars.
bump for a nice setup.
hondapowerb16a2
Dec 16, 2009 09:28 PM
Spoolin18
Mid-Atlantic (Sales)
Oct 30, 2007 07:25 PM
