safc2 base line for single cam
Old Jan 4, 2005 | 11:56 AM
gotboostedvr6's Avatar
Default safc2 base line for single cam
i have a d16y7 and a po6 ecu from a d15b7 with 450 dsm. im going to install a greddy turbo kit with fmic and i dont want to run it with out a decent base line high and low throttle settings. what should i start out with also i have no clue what the high and low thr % should be i was thinking 30 low and 60 high but i really dont know.thanks for any help u can provide. o yea i searched the faq but i really want someones baselines theyve used and had success with p.s. i dont have a wide band-thanks
Old Jan 5, 2005 | 01:18 PM
spoolnsol's Avatar
Default Re: safc2 base line for single cam (gotboostedvr6)
just set it to -36% on both high and low. GET TO THE DYNO SOON!!!!!! those settings should be good to just DRIVE on, no raping it! you do know that a afc advances the timing really bad right? if you don't have a msd btm, i would look into getting some kind of management. i have uberdata with dsm 450's and it works so much better than my afc did!
Old Jan 5, 2005 | 01:32 PM
Default Re: safc2 base line for single cam (spoolnsol)
that would be ok for a few weeks @ like 5 psi and 3 retard at the dizzy .and if ne one could tell me what is a safe air fuel ratio if i had a wide band to tune with.ive also herd of just watching the voltage out put of the narrow band what volt is lean and what is /rich
Old Jan 6, 2005 | 03:52 AM
spoolnsol's Avatar
you want a a/f of 12.0-12.5. i wouldn't trust the narrow readings unless you hate your motor!
Modified by spoolnsol at 2:12 PM 1/6/2005
Old Jan 6, 2005 | 09:06 AM
thanks
Old May 22, 2005 | 06:52 PM
eK9aT10pSi's Avatar
sorry to thread jack, when u had this installed, do you remmebr your knock settings/readings that you got?
gotboostedvr6
Jan 5, 2005 12:59 PM
BauleyCivic
Oct 5, 2004 08:10 AM
jeremy.
Oct 1, 2003 10:12 AM
toolowsol
Sep 17, 2003 06:27 PM
GraphiteAccord
Sep 1, 2002 04:03 AM
