help please problems with rear disc rotor
i have a 94 ciivic and swapped front and rear disc into it.. the everything is installed except the right rear rotor is giving me problems i took out the rotor screws with an impact wrench but the rotor is seized.
i sprayed a lot of liquid wrench etc.. i dont think i can use the screw bolts in the rotor method on the rear because it doesnt hit anything in the back unless you get a bolt that is like 5 inches long.
if i use a rubber mallet where do i hit to try to loosen in i dont want to mess the hub/bears , do i hit the rotor itself the front/back thanks
you should be abel to use a bolt since it will hit the hub that is right behind the top hat on the rotor. If not you can tap it on the top hat near the lug bolts just dont pound them instead avoid hitting the rotor with anything but a rubber hammer, you might dent it a bit. Also if you can try heating up the top hat a bit, it will make it a little easier
the bolt does not hit the hub on the rear disc integra brakes
you would have to use a 10x1.5 mm according to RJ , becuase there is no backing right behind the holes . i ended up getting it off by spraying PB liquid wrench a lot on back and hitting it with mallet a few times and it came off thanks
BrakeExpert
16
Feb 27, 2008 05:17 AM
VTECAcuraGSR
Oct 18, 2003 07:39 PM
