Best Honda/Acura Block and Head for Boosting
Old Jan 4, 2005 | 10:18 AM
wannabejdm's Avatar
Default Best Honda/Acura Block and Head for Boosting
Which is the best Block and Head to run alot of boost and make alot of Horse Power. Thinking of redoing my turboed motor.
Old Jan 4, 2005 | 12:45 PM
Luke J's Avatar
Default Re: Best Honda/Acura Block and Head for Boosting (wannabejdm)
d15b2..............................
Old Jan 4, 2005 | 03:21 PM
wannabejdm's Avatar
Default Re: Best Honda/Acura Block and Head for Boosting (Lucky925l)
what about a si motor?
b18a1 with a b16 head?
Old Jan 4, 2005 | 03:40 PM
EFRue57's Avatar
I hear gsr motors are the best for boosting
Old Jan 4, 2005 | 04:01 PM
drdisco69's Avatar
Default Re: Best Honda/Acura Block and Head for Boosting (EFRue57)
B16
Old Jan 4, 2005 | 04:03 PM
Luke J's Avatar
Default Re: Best Honda/Acura Block and Head for Boosting (drdisco69)
All of the big dogs run GSR heads
Old Jan 4, 2005 | 04:22 PM
hondaguyef's Avatar
Lots of pics and info on the best Motor for Boost: Click Here
Phil
Old Jan 4, 2005 | 04:50 PM
leadfoot78's Avatar
Default Re: Best Honda/Acura Block and Head for Boosting (hondaguyef)
Anything, as long as it has forged pistons and rods in it.
Old Jan 4, 2005 | 05:19 PM
hondaguyef's Avatar
Default Re: Best Honda/Acura Block and Head for Boosting (leadfoot78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leadfoot78 &raquo;</TD></TR><TR><TD CLASS="quote">Anything, as long as it has forged pistons and rods in it.</TD></TR></TABLE>
That's not true at all. The times in my sig were had on a completely stock Longblock!
Old Jan 4, 2005 | 05:43 PM
Luke J's Avatar
If I was building a motor for boost, and was wondering what combo for high horsepower, I would definitely sleeve it so that I don't have to worry about it.
-Stock sleeves will only support so much and last so long under boost.
Old Jan 4, 2005 | 07:06 PM
Bartman201's Avatar
the LS block can make good power
Old Jan 4, 2005 | 07:49 PM
EFRue57's Avatar
Default Re: Best Honda/Acura Block and Head for Boosting (Bartman201)
so basically everybody is gonna have their own opinion. i guess the best thing for you to do is research a little bit, and come to your own conclusion as to which motor you think would be best for what you intend to do to it.
Old Jan 5, 2005 | 06:17 AM
Aggressive Racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucky925l &raquo;</TD></TR><TR><TD CLASS="quote">All of the big dogs run GSR heads </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">I hear gsr motors are the best for boosting</TD></TR></TABLE>
GSR all the way
a type r crank would be nice too
https://honda-tech.com/zerothread?id=1097842 stuff for sale!
Old Jan 5, 2005 | 05:48 PM
StorminMatt's Avatar
If we are talking a complete stock block, possibly the best setup would be a B17A. It has a better rod ratio than the LS, GSR, B20, or D16 motors. This helps to reduce sleeve-cracking side loading (which can be significant on motors such as the LS or D16A). It has relatively low compression (9.7:1). And it has the overall stoutness of a VTEC motor. The GSR motor is also pretty good. Its compression is a little higher (10:1). But still not astronomically high. And its rod ratio is almost as good as the B17A.
A VERY good custom setup would be to use a B17A crank in an 84mm sleeved B18C. This would give you roughly the displacement of the B18C with the rod ratio of the B16A.
phelpsj2
10
Mar 18, 2010 12:02 AM
phelpsj2
Mar 17, 2010 02:09 PM
cutt
May 14, 2006 09:01 PM
2redstars
Jan 28, 2006 09:42 PM
Crx2092
Sep 7, 2004 05:32 PM
