O1 GSR Ecu ?'s
Old Jan 4, 2005 | 09:40 AM
ShortBusTechnologies's Avatar
Default O1 GSR Ecu ?'s
I have a 2001 GSR and the issue is RPM's. I would like to increase the RPM's so as to be able to extract more power out of the Skunk 2 Stage 2 cams I am running. Only problem is that Hondata does not support my ECU and I do not want the AEM EMS system. ($$ low) I was thinking that I could use a OBD2 to OBD1 conversion harness and get an OBD1 ECU and the S200 system from Hondata OR run a 98+ Type R ECU to get the extra revs (alone). Only thing is really I would just like to increase RPM's and thats it. Any suggestions? I hear I cannot run the s200 in the way I want because of the immobilizer. Doesn;t really make sense tho if I am going to run an OBD1 ECU. Once again, any suggestions. Searched to no avail.
Old Jan 4, 2005 | 10:16 AM
iH8RICERZ's Avatar
Default Re: O1 GSR Ecu ?'s (ShortBusTechnologies)
what mods do you have done.....?
Old Jan 4, 2005 | 10:25 AM
Default Re: O1 GSR Ecu ?'s (iH8RICERZ)
PnP head, Skunk2 Stage2 cams, cam gears, intake, DC 4-1 header, modified intake manifold, 68 mm TB, Portflow valvetrain, omni power valves. Some other stuff here and there.
Old Jan 4, 2005 | 01:18 PM
gsrboi80's Avatar
youll have to do the conversion to obd1 than u can run the hondata
Old Jan 4, 2005 | 01:54 PM
BlackSage's Avatar
Dont have experience with this but I will take a shot at it. I think the immoblizer has more to do with the ECU. If you buy a p73 (I think that is the ITR ECU) it might have an immobilizer, I know the 00-01 gsr's have one. You would have to take it somewhere to get it removed from the ECU. There was someone that made a thread for it. search for immbolizer and you should come up with it
HTH
Old Jan 4, 2005 | 02:31 PM
maggsgsr's Avatar
Default Re: O1 GSR Ecu ?'s (BlackSage)
95 P72 with dual mani
p28 with single stage
Old Jan 4, 2005 | 11:27 PM
Blown90hatcH's Avatar
The immobilizer is in the ecu. If you convert to OBd1, my conversion harness will jump the necessary pins to function the fuel pump. Then you can get a chipped P28 ecu from iH8RICERZ above for your setup or purchase a Hondata setup. You can also look into Crome or Uberdata as well.
Jason
http://www.JKobdconversionharness.com
Old Jan 5, 2005 | 02:14 PM
Default Re: O1 GSR Ecu ?'s (Blown90hatcH)
I have heard that the immobizer is near the ignition itself. I may be mistaken. So your saying that if I use your conversion harness (Blown90hatch) and run an OBD1 ECU and hondata (s200), that I can make it work?
Old Jan 6, 2005 | 09:20 AM
iH8RICERZ's Avatar
that is correct....I believe that the immobilizer is in the ecu itself, as well as the key.
Milab21
Engine Management and Tuning
Jan 14, 2009 06:18 PM
mattcivic
Jun 18, 2006 08:57 PM
ejmatzell
Mar 15, 2006 10:14 PM
TerribleOne
Dec 17, 2003 09:40 AM
yellowbuffalo
Jun 2, 2003 06:24 PM
