swapping
Old Jan 4, 2005 | 08:49 AM
b18c 94's Avatar
Default swapping
a jdm b18c goes into a 96 civic dx the same way as a civic 96 ex right? i mean the diff. btwn 1.5 to 1.6 will not make a diff in teh swap as far as the mounts and axels and whatever else is required for the swap goes right?
Old Jan 4, 2005 | 08:51 AM
turbotime's Avatar
i think some additional wiring for vtec is needed, but yeah the process is almost identical as far as mounts/axles/etc...
Old Jan 4, 2005 | 09:12 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: swapping (b18c 94)
the wire harness is a little different but it is about the same. you have a 3 wire iac valve you have to convert to a 2 wire valve, just match the 2 wires then terminate the third that isnt used. you wont have to worry about a ckf sensor unless you are goin to be obd2 compliant, but thats a whole nother story.
cheggie
Dec 15, 2011 11:36 AM
justinwazner
26
Nov 16, 2010 06:11 PM
andyvaj
Aug 11, 2007 09:24 AM
GREY_EK96
Jul 10, 2005 08:28 PM
