D16y8 AUTO tranny, replace axel seals????
Old Jan 4, 2005 | 12:45 AM
murmur9's Avatar
Default D16y8 AUTO tranny, replace axel seals????
Anyone know where I can find a how-to, or write-up on how to seplace them?
My tranny keeps leaving a puddle in my driveway. Its super bad now, for the past two weeks i probably have put a quart in it each week. I just drive it to work but I need to get it fixed quick. If I look at a manual write up...would it be SOMEWHAT similar? what other seals are likely to cause the tranny to drain so rapidly? TIA
EDIT: oh yea...I already searched my *** off. I found stuff on a lude....but no write-ups.
Old Jan 4, 2005 | 01:03 AM
_Cyclone_'s Avatar
Default Re: D16y8 AUTO tranny, replace axel seals???? (murmur9)
Make sure before you go nuts replacing seals that you crawl on your back under the car to see where the leak is ACTUALLY coming from. I wouldn't be very happy spending an hour of my time replacing axel seals, only to find that it's still leaking... from a loose drain plug or something no less.
Old Jan 5, 2005 | 12:49 AM
murmur9's Avatar
I have already been under my car quite a few times....searching....it seams to be coming from my right axel? by it? but if i am wrong, what others would you reccomend replacing while im doing this?
Old Jan 5, 2005 | 05:51 AM
Phatch99's Avatar
just go buy a helms manual and that should help u out on how to replace the seal.
Old Jan 7, 2005 | 10:55 AM
murmur9's Avatar
Default Re: D16y8 AUTO tranny, replace axel seals???? (Phatch99)
good looking out...but I already have one. I was just looking for peoples writeups...see what problems they came into....those FYI type of things....thanks though.
jcnichols22
Sep 28, 2013 11:58 AM
Loyal2amr
Apr 7, 2010 09:31 PM
gpolo69
Mar 18, 2008 09:22 AM
YoungKadafi
11
Oct 8, 2006 07:10 PM
Honda V-Tec
Feb 27, 2005 11:43 AM
