Need some help narrowing down a starting problem: '94 GSR
Old Jan 3, 2005 | 09:40 PM
Drian's Avatar
Default Need some help narrowing down a starting problem: '94 GSR
There are times when I turn the key the car makes a "one" click sound every time I turn the key to crank it. It also makes the "one" click when I hold the key down and move my clutch in and out. After awhile, it barely fires to life and sometimes it bogs out. When this happens I have to reset my clock/radio presets. I already changed my plugs. Now what else are my options?
Starter?
cap/rotor?
ignition switch?
distributor?
Thanks a million! I also search before I resort to a posting, so any help is appreciated.
Old Jan 3, 2005 | 09:55 PM
Drian's Avatar
Old Jan 4, 2005 | 12:35 AM
[626]95-GSR's Avatar
Default Re: Need some help narrowing down a starting problem: '94 GSR (Drian)
First off, you should check the obvious. Check all the grounds to the battery and to the starter itself. Check and make sure your battery is charged up and all the connections are good. You say that your clock/radio needs to be reset, MAKE SURE to check all the connections to the battery and charging system (alternator). Have you tried giving the motor a "jump"?... theres a BIG chance your battery needs to be replaced.
It could also be a problem with the started itself, more specifically the starter solenoid. That "click" you are hearing is the solenoid trying to spin the starter motor. Try tapping on the starter motor with a hammer or a rod (lightly). If the starter works after that, then you have to replace the starter motor.
If it was the ignition system(cap/rotor, distributor) the engine would at least turn over a few times attempting to start.
If it were the ignition switch, you would not hear the "click" from the starter solenoid.
Old Jan 4, 2005 | 08:02 AM
gt30typer's Avatar
Default Re: Need some help narrowing down a starting problem: '94 GSR ([626]95-GSR)
Starter ground? Starter power is probably arcing across or loose
Old Jan 4, 2005 | 08:15 AM
The Poopsmith's Avatar
i had this problem, it turned out to be a bad relay on my alarm. I would check all the electrical connections first
Old Jan 4, 2005 | 10:50 AM
Drian's Avatar
Sweet. THanks alot. Will start a check list after work. Thanks for all the great help!
thaisayz
17
Feb 11, 2010 09:19 AM
SiB16A
Jun 11, 2006 12:37 PM
FalconMan
Aug 19, 2005 06:02 PM
Accord15
Feb 21, 2003 09:47 PM
tan2
Nov 4, 2002 10:10 AM
