Tire stretching 15x7 with 195/50/15 bad???
I am getting new 15x7 rims but already have 195/50/15 tires that i bought 3 months ago, is this wheel & tire combination bad? If you have this combination please express your opinion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solo2EG »</TD></TR><TR><TD CLASS="quote">No problem, I had 195-50-15 on 15x7 for years... the wider the better.</TD></TR></TABLE>
195 is stock width and not 205 which is also able to fit
Perfectly fine. I had 195-50-15's on my 15x7 fittipaldis and they were absolutely fine. Looked really nice too, doesnt have that balloon look you get with 195-55's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz »</TD></TR><TR><TD CLASS="quote">please tell me you are putting this on a 90-93 integra. 195/50 is DANGEROUS for a 94-01 integra. It can not handle the load.</TD></TR></TABLE>
how does going from 55 to 50 make it more dangerous? is it because of the heat created when on the highway?
from tirerack
A tire with a higher load index than that of the Original Equipment tire indicates an increase in load capacity. A tire with a load index equal to that of the Original Equipment tire indicates an equivalent load capacity. A tire with a lower load index than the Original Equipment tire indicates the tire does not equal the load capacity of the original.
195/55/15 has a load rating of <FONT COLOR="green">85</FONT>
195/50/15 has a load rating of <FONT COLOR="red">82</FONT>
205/50/15 has a load rating of <FONT COLOR="green">86</FONT>
http://www.tirerack.com/tires/...d.jsp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz »</TD></TR><TR><TD CLASS="quote">from tirerack
http://www.tirerack.com/tires/...d.jsp</TD></TR></TABLE>
There is additional info on that tirerack page that might be relevant:
82 = 1047 lbs -- multiplied by 4 = 4188 lbs
85 = 1135 lbs -- multiplied by 4 = 4540 lbs
Googling shows 1994 GS-R sedan has a curb weight of 2628 lbs.
So unless you're carrying close to 1560 lbs (which included occupants), it would seem 195/50/15 is fine.
I have to admit, I hadn't considered load rating before....
i would go w/ 205 rather than 195, the small extra weight isn't gonna make a difference, it'll depend on what tires you go w/ too, 205 just give you wider contact patch and better look, i think the 195 would come short w/ the 15x7, it's better for 15x6.5 IMO,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1whitedc2 »</TD></TR><TR><TD CLASS="quote">i would go w/ 205 rather than 195, the small extra weight isn't gonna make a difference, it'll depend on what tires you go w/ too, 205 just give you wider contact patch and better look, i think the 195 would come short w/ the 15x7, it's better for 15x6.5 IMO, </TD></TR></TABLE>
A couple other things that might factor into the decision:
Some tires don't come in 205/50/15, but do come in 195/50/15, such as Goodyear Eagle F1 GS-D3. This is #1 max performance tire on tirerack's survey.
Some tires are significantly less expensive in 195/50/15 than in 205/50/15.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drive4show »</TD></TR><TR><TD CLASS="quote">
Some tires are significantly less expensive in 195/50/15 than in 205/50/15.</TD></TR></TABLE>
you hit the nail on the head!! those are the exact tires i am running now..thats why i wanted to know...
2000GSR
Jan 31, 2006 07:45 AM
