Question: Pro's/Con's of running a "tight" tire/rim combo..
Old Jan 3, 2005 | 08:32 PM
K-Twizzle's Avatar
Default Question: Pro's/Con's of running a "tight" tire/rim combo..
Lets say for example a 205 on an 8" rim.
I know you get a very nice turn-in, but are there any other pro's/con's?
b/c right now I have 225's on them and I rub if I zero out the camber + hard turn, and I'm pretty sure if I have 205's or even 215's I won't rub @ zero camber.
Old Jan 3, 2005 | 08:53 PM
stormy's Avatar
Default Re: Question: Pro's/Con's of running a "tight" tire/rim combo.. (K-Twizzle)
I think what you really want to know is by increasing the rim width will it decrese rollover allowing you to run zero camber while still maintaining a high traction limit.
and that really depends on your suspension and the tire
Old Jan 3, 2005 | 08:54 PM
carl_aka_carlos's Avatar
why on earth would you want 0* camber for road racing or autocross?
Old Jan 3, 2005 | 09:02 PM
stormy's Avatar
Default Re: Question: Pro's/Con's of running a "tight" tire/rim combo.. (carl_aka_carlos)
daily driver most likely
the real question is IMHO
why would you really base a setup to perform only during extreme tire rollover
Old Jan 4, 2005 | 06:18 AM
K-Twizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carl_aka_carlos &raquo;</TD></TR><TR><TD CLASS="quote">why on earth would you want 0* camber for road racing or autocross?</TD></TR></TABLE>
Well its not really zero.. its just not as negative... real numbers are about -.082-0.84
Old Jan 4, 2005 | 06:22 AM
K-Twizzle's Avatar
Default Re: Question: Pro's/Con's of running a "tight" tire/rim combo.. (sans)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sans &raquo;</TD></TR><TR><TD CLASS="quote">I think what you really want to know is by increasing the rim width will it decrese rollover allowing you to run zero camber while still maintaining a high traction limit.
I don't want to increase rim width, I want to decrease tire width and not to have to run excessive camber for the wheels to clear the fender/qtr panel.
The rims are 16x8 and 225's all around. It fits and runs fine as it is but I had to raise the car, and I don't like the 1" gap between the tire/fender.
So I want to know if I go down to 215's or 205's will I have just as good traction?
Any con's to running a setup like that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sans &raquo;</TD></TR><TR><TD CLASS="quote">daily driver most likely
why would you really base a setup to perform only during extreme tire rollover</TD></TR></TABLE>
Yes it is a daily driver.
I'm not basing it only on extreme tire rollover, that was just an example.
I'm looking for the pro's con's of the setup.
Old Jan 4, 2005 | 06:35 AM
stormy's Avatar
the cons would be excessive tread wear since your in effect pulling the tire constantly and a rough ride similar to 18's with a 35 series tire
Old Jan 4, 2005 | 09:34 AM
Black R's Avatar
25 Year Member
why not just roll the fenders to gain more clearance?
I wouldn't want to take away traction.....
Old Jan 4, 2005 | 05:09 PM
K-Twizzle's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">why not just roll the fenders to gain more clearance?
I wouldn't want to take away traction..... </TD></TR></TABLE>
Fenders are rolled. 16x8 and a +38 offset.
I might just have to deal w/ the ride height.
Old Jan 4, 2005 | 05:30 PM
Black R's Avatar
25 Year Member
Default Re: (K-Twizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K-Twizzle &raquo;</TD></TR><TR><TD CLASS="quote">Fenders are rolled. 16x8 and a +38 offset. </TD></TR></TABLE>
Roll them some more. If that doesn't work, then cut and/ or flare them.
Old Jan 5, 2005 | 09:58 PM
I'd want at least -1.5* camber up front, with the camber setting you have and some stretched tires you're gonna burn through the outside shoulders of your tires.
Old Jan 6, 2005 | 11:12 PM
K-Twizzle's Avatar
Default Re: (carl_aka_carlos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carl_aka_carlos &raquo;</TD></TR><TR><TD CLASS="quote">I'd want at least -1.5* camber up front, with the camber setting you have and some stretched tires you're gonna burn through the outside shoulders of your tires.</TD></TR></TABLE>
ok , cool. I'll just see if i can roll some more.
Old Jan 7, 2005 | 06:31 AM
rodimus's Avatar
K-Twizzle likes his ride slammed with 99,999 pound spring rates.
what a tool
my_gsr_teg
Apr 29, 2010 05:13 PM
andyhansana
Nov 28, 2007 08:34 AM
blinger
Oct 18, 2007 06:36 AM
B16CRXT
Suspension & Brakes
Jul 20, 2006 09:38 PM
sackdz
21
Oct 1, 2003 12:59 PM
