Whats This?
Old Jan 3, 2005 | 08:27 PM
THEUSED's Avatar
Default Whats This?
I picked up a GSR IM and TB and there is nothing right here on the Bottom of the TB whats suppose to be there?
Old Jan 3, 2005 | 08:47 PM
Dan GSR's Avatar
Default Re: Whats This? (THEUSED)
FITV
Old Jan 3, 2005 | 08:51 PM
eastbay92cx's Avatar
I believe the fast idle valve goes there, that is the usual spot for it although I've never worked on a gsr motor. It has coolant running through it and lets some air bypass the tb butterfly depending on coolant temp. You could try leaving it unhooked as is, or plugging those air holes up if you can't find a fast idle valve, depending on the climate where you're at you might be able to get by w/o it. Then again it might make your car idle funny w/o one. Good luck.
Old Jan 3, 2005 | 09:09 PM
eda6's Avatar
Default Re: Whats This? (eastbay92cx)
I don't have a fitv. I start my car up and it idles at 750 rpm. My right foot became the fitv
Takes the car longer to warm up w/o it.
Old Jan 3, 2005 | 09:13 PM
THEUSED's Avatar
So should I not worry about it or go get one?
Old Jan 4, 2005 | 05:33 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: (THEUSED)
try with out it first, if you don't like it get on then
stockCRXsi
13
Jun 7, 2007 02:25 PM
gregory
Oct 15, 2006 07:15 AM
gotsmokedright2
Feb 20, 2004 03:13 AM
hybrid901
May 29, 2003 07:20 AM
Wicked Sol
Mar 6, 2003 05:49 AM
