High whp D's - valve cover venting?
Old Jan 3, 2005 | 07:16 PM
MooreBoost's Avatar
Default High whp D's - valve cover venting?
Here are some pics of a Z6 valve cover.
In this pic you can see the area that is baffled.
This is the side of the cover, with the top of the cover towards the top of the pic. I am pointing to the lowest point that the baffling is at on the inside of the cover.
Since there isn't much room to tap on the back of the cover, and even less on the front, I figured I would fine some small barbed 90 degree fittings, and tap the top of the cover in two spots, which I am pointing to.
Does anyone see any issues with that? And does anyone know where I could find some fittings that would work?
Modified by MooreBoost at 6:24 PM 1/23/2005
Old Jan 4, 2005 | 04:02 AM
MooreBoost's Avatar
Default Re: High whp D's - valve cover venting? (MooreBoost)
Old Jan 4, 2005 | 05:54 AM
The ZC's Avatar
I'm going to be running high numbers soon so I'd like to know as well.
Old Jan 4, 2005 | 06:29 AM
AR Fab's Avatar
Default Re: High whp D's - valve cover venting? (The ZC)
nothing special yet....just vent the valve cover to a catch can....hell my car had a 1" Filter on it...lol
Howard
Old Jan 4, 2005 | 06:59 AM
ELSpool's Avatar
I ran a line from the black box (PCV removed on Y8) on the back of the motor to a catch can and the same with the valve cover as well.
Old Jan 4, 2005 | 07:54 AM
xci_ed6's Avatar
Default Re: (ELSpool)
i had a greddy style catch can, and replaced the seperator box w/ it. basically just plumbed the catch can in between the port on the block and the PCV valve.
Next setup is staying with the box in place and adding a small catch can between the PCV and the block.
Old Jan 4, 2005 | 09:10 AM
platinum00's Avatar
Default Re: (krustindumm)
i cut the black box in half and removed the baffling, welded it back together with a fitting on it. it runs to a catch can with a breather filter on top.
running filter on valve cover.
looking for other options though
platinum.
Old Jan 4, 2005 | 10:44 AM
xci_ed6's Avatar
Default Re: (platinum00)
when i removed the box, i threaded in a 3/4" male NPT to 1/2" barb fitting.
Old Jan 4, 2005 | 12:11 PM
MooreBoost's Avatar
Are the Z6 valve covers baffled? I hear if you tap it for venting you need to baffle it first, or tap in a baffled spot, so that oil doen't get out also.
It seems like there are alot of different ways to do it, does anyone know which is the most effective, and anyone with pics of their setup, especially of the back of the block, please post!
Old Jan 4, 2005 | 04:13 PM
MooreBoost's Avatar
Default Re: (MooreBoost)
Old Jan 4, 2005 | 07:06 PM
MooreBoost's Avatar
Lets get some info!
Old Jan 5, 2005 | 06:13 PM
MooreBoost's Avatar
Old Jan 5, 2005 | 06:54 PM
djfob's Avatar
I did mine like this
Old Jan 5, 2005 | 07:09 PM
MooreBoost's Avatar
Default Re: (djfob)
Ill look into that also but Im more worried about valve cover venting.
Old Jan 5, 2005 | 07:35 PM
CivicEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">Ill look into that also but Im more worried about valve cover venting.</TD></TR></TABLE>
Mine goes from valve cover pvc hole to turbo intake...
Modified by CivicEJ1 at 8:47 PM 1/5/2005
Old Jan 5, 2005 | 07:44 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (CivicEJ1)
i have a carbing catch can on mine. hooked it up to the intake manifold and to the pcv valve and left the valve cover open atmosphere...i get no blowby
Old Jan 8, 2005 | 07:00 AM
MooreBoost's Avatar
Old Jan 8, 2005 | 07:13 AM
dasher's Avatar
Default Re: (djfob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djfob &raquo;</TD></TR><TR><TD CLASS="quote">I did mine like this
how many miles have you used this setup? have you inspected the compressor housing and intercooler for oil buildup?
Old Jan 8, 2005 | 10:08 AM
MooreBoost's Avatar
Default Re: (dasher)
Good point dasher, if the sump doesn't pick it all up your also running it through the turbo/piping/fmic, and not just the engine itself like you would if it returned at the intake mani.
I looked over your thread on this stuff, did you ever come to a conclusion as to what would be the best setup for a boosted motor?
Old Jan 8, 2005 | 10:18 AM
dasher's Avatar
Open catchcan ventilation or exhaust assisted ventilation all work fine from a performance perspective.
Or you could spend alot of money and get a z10 vacuum ventilation which would be ideal. $$$$$$
Old Jan 8, 2005 | 06:52 PM
MooreBoost's Avatar
But how would you route it? From the PVC to catch can to intake mani? And then run a few valve cover vents?
Old Jan 23, 2005 | 09:25 AM
MooreBoost's Avatar
Old Jan 23, 2005 | 01:53 PM
MooreBoost's Avatar
Bump for pics.
Old Jan 24, 2005 | 11:09 AM
JDMCRX's Avatar
The way DJFOB is the way im gonna do mine but im gonna weld two bungs on the rear of the cover and plumb them into the catch can. Cause here in ont if u do not have ur **** plumbed u get a fine for emissons 356 dollars.
Old Jan 24, 2005 | 11:10 AM
JDMCRX's Avatar
Just putting a filter on the valve cover when u get pulled over well here in t.o u get nailed $356 so im gonna make sure my ***** good last thing i want is a fine for that BS.
