installing rear springs
Old Jan 3, 2005 | 07:14 PM
dcrbin22's Avatar
Default installing rear springs
Hey anyone know an easier way to get the rear shock spring assembly in place. Im having a hard time getting it to clear , and just get it up in there the shock is really stiff and hard to compress. Is there something to unbolt to give some more room ?
Old Jan 3, 2005 | 07:31 PM
recklessfour's Avatar
Default Re: installing rear springs (dcrbin22)
tried using sping compressor? maybe compressing the springs will help remove the shocks out.
Old Jan 3, 2005 | 09:14 PM
boostedlude97's Avatar
there is a bolt that is on the end of the upper ball joint held on by a cotter pin
pull the pin out and loosen the bolt. hit the upper A arm with a soft hammer and pull down on the compensating arm.............
Old Jan 4, 2005 | 01:24 PM
SNsLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chase &raquo;</TD></TR><TR><TD CLASS="quote">
I'll second that, however it's a nut on the ball joint, not a bolt . When separating, do not use a fork or other means to pull the ball joint, as boostedlude97 said just hit the knuckle with a hammer and it will pop off. That'll make it much easier to intall the suspension...</TD></TR></TABLE>
i used a pittman arm puller and it worked just dandy... depending on how stuck the joint really is tho, might want to concider a sledge hammer bc arm pullers can really damage the thread/boot...
also if you have a friend with you, you can have him put pressure on your rotor from the top to give oyu more clearance to move the assembly around, thats what i had to do to get my rear assemblies in... good luck with that
Old Jan 4, 2005 | 06:21 PM
dcrbin22's Avatar
Default Re: installing rear springs (SNsLude)
Yeah i tried to get get the upper arm off but its stuck good. I didnt want to damage it so i stopped i putting it on a lift tomorrow should be easier to do. The setup is neuspeed sports/bilstein shocks , im taking the sleeve coils out. Those were easy to install , they are half the size of the neuspeeds springs.
Old Jan 4, 2005 | 06:40 PM
SNsLude's Avatar
gl with that man... let us know how it turns out/rides
Old Jan 4, 2005 | 07:32 PM
dcrbin22's Avatar
Thanks it should ride a lot better the coils were cheap ebay ones.
civlxbro
Suspension & Brakes
Oct 4, 2009 07:51 AM
SoullessJapaneseMachine
Jun 19, 2008 09:56 AM
Cooker4418
Nov 5, 2006 02:05 PM
96tegman
Jun 8, 2006 04:16 AM
Ax3l
Suspension & Brakes
Jul 18, 2005 12:53 PM
