Exhaust Gasket Question
I have a carsound cat (2.5") bolted up to a stock ITR B pipe. The stock gasket does not fit with the bigger diameter cat. Can someone point me in the right direction of a gasket that will fit?
Thanks in advance
Thanks in advance
from the FAQ at the top of the page.
https://honda-tech.com/zerothread?id=1067321
That seems to be the gasket that goes between the cat and the header, I need a gasket to go between the cat and the b-pipe, or does the same gasket work in either place?
Thanks again!
Thanks again!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ferrell »</TD></TR><TR><TD CLASS="quote">Are you needing the donut gasket?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellow Submarine »</TD></TR><TR><TD CLASS="quote">I need a gasket to go between the cat and the b-pipe</TD></TR></TABLE>
basically you just need a 2.5" 3-bolt gasket from what i understand. kteller.com sells those...
