how often do you change your tranny fluid?
changed my tranny fluid today and i did not feel any difference in shift feel, and this is the first time i have changed it (car has 33,000 miles)what type of noticeable differences do you guy's feel when you change your tranny fluid? cause i notice some of you change very often.
also any of you put the new fluid through the whole where the vehicle speed sensor goes? a friend of mine puts his through there and its a whole lot easier than putting it through the whole in the bottom
[Modified by xlr8 si, 9:26 AM 1/8/2002]
do you guys find it that important to change your fluids i don't see the point to change it so often, maybe once a year or so...unless you guys drive the hell out of your R
I change my oil every two weeks or 2000 miles(whichever comes first)
and the trans fluid every other oil change.
And yes, i drive the **** out of my car.
was just talking about this with 401-2001, i read him the helm and deterred him from doing it early, now i'm wondering if i shouldn't do it myself...
Every 3000 miles I do...
-oil change
-trans fluid change
-distributor rotor
-spark plugs (inspect)
Every 9000 miles I do...
-coolant w/ Water Wetter
-distributor cap
-spark plug wires
-brake fluid
I guess you could call it extreme, but if you worked for Acura and the prices I get applied to you, I'm sure most of you would do the same.
And yes, I keep my old parts. (For those who think I am crazy for changing plug wires like underwear).. so if any of my friends ever need parts to throw a motor together, etc.. the parts are there.
-oil change
-trans fluid change
-distributor rotor
-distributor cap
-spark plug wires
-brake fluid
change it every 15000 . you will be glad you did at 120,000. oil every 3000
every other engine oil change
I was changing every 5k miles and then after opening up the tranny and seeing how dirty it was in there I'm going to be doing it per yack's suggestion.
I don't think the manual takes into account the amount of racing we put our cars through - even under the severe conditions recommendations.....
redline at least 1st-3rd gears a few times a day
and my redline is 10000rpm. <evil grin>
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
I change mine whenever I get the urge to. What I really need to do is bleed out the clutch fluid. 40k and counting
So far tranny fluid has been changed 3 times, twice with honda mtf and now redline mtl.
around every 5000km (roughly 3000+ miles). much more than that and the LSD gets clunky and noisy. If you are using the stock LSD though, then it's not such a big deal
acydphryck
Jan 23, 2003 11:37 AM
professorman
Jan 12, 2003 06:40 AM
