HELP CANT GET POWER TO HEAD UNIT!!
i have a 95 integra ls and i got it a few days ago and It had the stock head unit in but not completely installed, and i couldn't get the access codes to get it to work so i just went to best buy and got a new head unit. Its some model pioneer i dont remember.
So i hooked up my new head unit with the new wiring harnes that i needed to get it to hook up. I got it all installed and it turned on and played music just fine. Then i turned my car off and turned it back on again and there was no music but the head unit had power. So i checked to make sure everything was hooked up correctly and it was Then i turn my car on again and there was no power at all to my head unit. So i went and had my car guy check it out and he said that if i got a new stock wiring harness like from a wrecked integra that it would most likely fix it.
So i went to the junkyard and got my new harness out of a 98 gsr and i got him to wire it all up for me just in case it was my incompetence that messed everything up. But it still didn't work so now i have no idea what is wrong with it.
Oh yeah i also returned my first pioneer to get a new one just in case it was broken and i wired it up in my explorer with my harness that i bought and it worked fine.
ANY help will be appreciated that you!
for christ sake, its a freaking honda. Any installer worth five bucks can troubleshoot this problem. First of all, you should go back to whoever it was that told you to get a new harness and just beat the **** out of him. If not for making you spend money on stupid ****, then do it for me. Second all you need is three things for the H/U to turn on, Constant Power, Ignition, and Ground. Yellow, Red, and Black. Now if you have a system ie: amplifers etc, then you will need to have the Blue w/ White wire running to your amplifiers. If you do not then you need to check all of your speaker wire connections. I know for a fact that integras do not have factory amplifiers so thats out. Worst comes to worst, you can re-run your wires and bypass the factory wiring all together. But at this stage, id recommend you take it to someone who knows wtf theyre doing.
SpecialRequest
Apr 27, 2016 01:29 PM
crxaddikt
Audio / Security / Video
Mar 14, 2014 04:40 PM
Stockton
Sep 17, 2007 05:29 PM
