Blinkers not working..plz advise
Old Jan 3, 2005 | 11:19 AM
bgmat58's Avatar
Default Blinkers not working..plz advise
Guys..I noticed the other day that my blinkers are not working, the reason this came to my attention is because the blinking sound didnt come on when I put my blinker on. Anyone know what it may be and how I can fix it? Thanks in advance.
Old Jan 3, 2005 | 11:43 AM
alotawatts's Avatar
Default Re: Blinkers not working..plz advise (bgmat58)
Start by replacing the relay
Old Jan 3, 2005 | 12:00 PM
fw190bvi's Avatar
Default Re: Blinkers not working..plz advise (alotawatts)
is the clock on the dash still displaying??......they are on the same circuit, and if that was disconnected, the bilnkers wont blink in the cabin....did you mess with any of the dash wires??....did you check the fuse box.....??
Old Jan 3, 2005 | 04:02 PM
aZnAcCoRd02's Avatar
probably a blown fuse, so yeah check the fuse box
Old Jan 3, 2005 | 07:39 PM
Rainman15's Avatar
Default Re: Blinkers not working..plz advise (aZnAcCoRd02)
If the hazard flashers button is pushed in the turn signals will not work. This happened to me a couple weeks ago. The hazard fuse under the hood blew and I had the button pushed in on the dash and didn't know it. Must have hit it adjusting the radio or something. Check that fuse under the hood labeled hazard.
Old Jan 3, 2005 | 08:45 PM
F23Coupe's Avatar
Did you check the blinker fluid? It's where the fuse box is. If it's low, refill it with some ATF.
J/k. Hope I didn't fool anyone. Try the hazard lights and see if that works.
Old Jan 5, 2005 | 06:13 PM
bgmat58's Avatar
Default Re: Blinkers not working..plz advise (Rainman15)
Thanks alot guys..you were right rainman..it was the flasher button, it was pushed in and like you I dont have a fuse for the flashers. Thank you, one less thing to worry about!
Old Jan 5, 2005 | 08:44 PM
CD7power's Avatar
Default Re: Blinkers not working..plz advise (F23Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F23Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Did you check the blinker fluid? It's where the fuse box is. If it's low, refill it with some ATF.
J/k. Hope I didn't fool anyone. Try the hazard lights and see if that works.</TD></TR></TABLE>
LOL...that had me thinkin for a while untill i read the j/k part
EgHatchy96
Aug 26, 2013 12:27 AM
josh_db1
Jun 12, 2010 02:46 PM
AcInTheEg
Audio / Security / Video
May 2, 2007 04:05 AM
free99
Mar 6, 2007 12:14 PM
AssPenny
Jan 7, 2002 09:29 AM
