Wierd Squeeking Noise??
Old Jan 3, 2005 | 08:55 AM
WtPanther's Avatar
Default Wierd Squeeking Noise??
Just reciently my lude started making a faint, but noticable squeeling noise. It only sounds at certain speeds tho. Like from 1-about 20 mph, you can hear it. any speed higher than that its fine. also it squeels around turns. I have no idea what it could be. Any1 have a clue?
By the way.. i dont kno if this matters at all, but my brakes are getting low. maybe that has something to do with it?
Old Jan 3, 2005 | 09:01 AM
Altilude's Avatar
Default Re: Wierd Squeeking Noise?? (WtPanther)
is it not your belts slipping? 1 - 20 is usually when you're accelerating and often the time when belts slip most - once throttle position levels out the belts tend to regain "traction" and run fine... does it squeak when you first start up too?
Old Jan 3, 2005 | 09:11 AM
redlude97's Avatar
I had and Am having the same problem again. The first time I took it in my brakes were rusted, so thats why they said it was making that noise. But Im not sure why its doing it agian, so we are in the same boat.
Old Jan 3, 2005 | 10:11 AM
WtPanther's Avatar
Default Re: Wierd Squeeking Noise?? (Altilude)
it does it at low accel too.. no id doesnt do it at first start. I was told that it may be my wheel bushings or bearings????
coolaid119
Aug 8, 2017 10:13 AM
Hella_Fresh
May 8, 2006 10:00 AM
ryan94lude
Sep 20, 2005 07:17 PM
eg ferio
41
Jan 2, 2005 07:08 PM
DeregginOut
Jul 4, 2002 11:40 AM
