Still leaking oil after 2 attempts to fix it????
Old Jan 3, 2005 | 08:09 AM
DrewQ1's Avatar
Default Still leaking oil after 2 attempts to fix it????
I'm still getting oil in my spark plug tubes, after i have changed the seals twice, what can be the problem????? someone help me out and let me know.
Edit: Will that also cause for me to burn oil or is it just me cause I put about 3k miles about every month or so on my car which is about half a quart every other week or so.
I just realized i didnt put the breather hose or whatever hose that is back in that hole on top of the valve cover. Now i'm hoping maybe thats the reason i'm still getting oil in my tube seals, But the first time i did it, i remember to put it back in, but in case thats not the problem, what could it be?
Modified by DrewQ1 at 11:38 PM 1/3/2005
Old Jan 3, 2005 | 11:23 AM
DrewQ1's Avatar
Default Re: Still leaking oil after 2 attempts to fix it???? (DrewQ1)
any suggestions?
Old Jan 3, 2005 | 11:30 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Use gasket sealer.
make sure the bolts are torqued right, and they are all there.
Old Jan 3, 2005 | 11:41 AM
DrewQ1's Avatar
Default Re: Still leaking oil after 2 attempts to fix it???? (JDM_Ej)
did all that, was i supposed to add honda bond, i keep hearing from different sources that i should or shouldnt
Old Jan 3, 2005 | 12:52 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewQ1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm still getting oil in my spark plug tubes, after i have changed the seals twice, what can be the problem????? someone help me out and let me know.</TD></TR></TABLE>
What year and model? Which seals did you replace?
Old Jan 3, 2005 | 02:39 PM
DrewQ1's Avatar
Default Re: Still leaking oil after 2 attempts to fix it???? (Chiovnidca)
Its a 95 Integra LS. Valve cover gasket and spark plug tube seals.
Old Jan 3, 2005 | 04:48 PM
drdisco69's Avatar
No hondabond is needed. Make sure your PCV system is working, that can make you burn oil and force oil past those seals from the pressure in the crank case.
Old Jan 3, 2005 | 07:17 PM
DrewQ1's Avatar
Default Re: Still leaking oil after 2 attempts to fix it???? (drdisco69)
Whats do you mean?
Old Jan 3, 2005 | 07:39 PM
DrewQ1's Avatar
i'm bored so heres a bump!
Old Jan 3, 2005 | 07:52 PM
nvmyb20hatch's Avatar
what hes saying is that without the pcv working properly crankcase vapors cant be rerouted into your intake and end up building up and causing the seals the swell and/or leak
Old Jan 3, 2005 | 08:19 PM
DrewQ1's Avatar
Default Re: Still leaking oil after 2 attempts to fix it???? (nvmyb20hatch)
but even after a day and half of driving?
Old Jan 4, 2005 | 02:28 PM
DrewQ1's Avatar
any new ideas?
ThrowSomeDs
Oct 30, 2006 05:06 PM
creep_gunner
Sep 11, 2005 08:30 AM
NinjaTech
May 21, 2005 11:06 PM
DrewQ1
Jan 4, 2005 02:31 PM
grandmasterflex
Mar 16, 2004 03:49 PM
