swapped B18b into 92 DA, having problems.. engine turns on but won't stay on
just swapped a 2000 B18b into my 92 DA. The problem is that the engine turns on but it won't stay on. Need some help?
Thanks..
Thanks..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldtegskoo90 »</TD></TR><TR><TD CLASS="quote">u kept your b18a obd1 dizzy, injector and manifold on? to keep it obd1?</TD></TR></TABLE>
check vacum lines, and spark plug wires, also play with your idle air screw or even the throttle cable. does the engine run like **** when it runs? all your sensor plugs went back to the same spot right? cause some of plugs fit where they shouldnt...honda just being cheap
j/k
j/k
