N/A or BOOST ?
Old Jan 2, 2005 | 07:57 PM
SD1222's Avatar
Default N/A or BOOST ?
alright guys i've been debating if i should turbo my 94 civic hatchback LS swap or go all motor? Keep in mind if i do go turbo or all motor im not going all out as in fully builting my motor. If i go turbo i'll just put a turbo kit on and boost it safely around 6psi so i wont blow my motor, and if i do go all motor it'll just be the basic bolt-ons such as intake, exhaust, header and cams. The reason why im asking this is because im planning on getting some camshaft from crower but i don't know which ones imma get since there's differences between the camshaft for turbo and non turbo cars. For all motor im looking at getting the 403 from crower since that's the most popular one and if i go turbo i'll get the 402T. Any suggestion on what will be a better choice for a daily driven car with enough power to back it up?
Old Jan 2, 2005 | 07:59 PM
Ekay Jay's Avatar
Default Re: N/A or BOOST ? (jdm_spoonEG)
umm, wrong forum..... Post in civic forum
Old Jan 2, 2005 | 08:03 PM
mEr's Avatar
mEr
Default Re: N/A or BOOST ? (93 InTeGrA Rs)
^^yup................
<U>
NA IS BEST!!</U>
Old Jan 2, 2005 | 08:11 PM
Kicklow's Avatar
Default Re: N/A or BOOST ? (mEr y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 InTeGrA Rs &raquo;</TD></TR><TR><TD CLASS="quote">umm, wrong forum..... Post in civic forum</TD></TR></TABLE>
agreed...but go boost!!
Old Jan 2, 2005 | 08:13 PM
SD1222's Avatar
Default Re: N/A or BOOST ? (Kicklow)
dammit i thought this was for off-topic.. moving it to civic forum, my bad.
Old Jan 2, 2005 | 09:27 PM
hasback*'s Avatar
F*CK THIEVES!
BOOOOOOOOOOOOOOOOOOOOST
Old Jan 2, 2005 | 09:30 PM
mrDFWmechanic's Avatar
since you have an ls motor swap i would turbo it because the compression is good for turbo and you can safely boose 10+ pounds and no problem. if you were to do an all motor you would either need a gsr or type R motor and fully build that up which would just be more expensive than turbo'ing the ls
africanqueen's Avatar
Default Re: N/A or BOOST ? (hasback_00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hasback_00 &raquo;</TD></TR><TR><TD CLASS="quote">BOOOOOOOOOOOOOOOOOOOOST </TD></TR></TABLE>
hmmmmmmmmmmm---that sounds good---BUT ITB's are nice 2
get what ya want
Old Jan 2, 2005 | 09:31 PM
with your LS---boooooooooooooooooooooooosssssssssssttttttttttttt
Old Jan 2, 2005 | 09:34 PM
plusONE jboy's Avatar
you will have lots of fun with boost. then again im biased.
streetking898
Jan 24, 2007 08:50 PM
shibikku95
23
Jun 30, 2006 06:00 PM
vpower
Jun 8, 2006 08:34 PM
SD1222
14
Jan 2, 2005 09:36 PM
CRX_Type_R
Nov 19, 2004 10:49 PM
