timing belt question
Old Jan 2, 2005 | 07:43 PM
F20B EG6's Avatar
Default timing belt question
my bud just swapped a jdm h22 into his 92 prelude. he only had it running for a few weeks and he fucked up his clutch. fixed it then he had it running for a few days and his timing belt grenaded. it just shredded and fell apart.why would it do that?
and someone told me that normally its a good idea to replace the timing belt on a swap when you first get it? is that true?
is it safer that way?
thank you.
Old Jan 2, 2005 | 08:19 PM
eda6's Avatar
Default Re: timing belt question (bucknut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bucknut &raquo;</TD></TR><TR><TD CLASS="quote">me that normally its a good idea to replace the timing belt on a swap when you first get it? is that true?
thank you.
I've broken two. Fixed the bent valves. Bought another honda, planned to change it, it broke before i got to it. Changed some more bent valves. Did a swap and this time i changed it before start-up. It's always a wise decision to change the timing belt belt and water pump whenever you get a new motor/honda.
Old Jan 3, 2005 | 09:48 AM
PrettyLude's Avatar
its alot easier to do it outside of the car
Old Jan 3, 2005 | 12:39 PM
F20B EG6's Avatar
Default Re: (PrettyLude)
awesome. thats what i thought. thanks man.
tegsr2o3
Mar 24, 2009 02:03 PM
FearDisH22a4
Aug 30, 2008 08:53 PM
thunderboy
Aug 21, 2008 05:05 PM
jjaeschke2
Apr 7, 2003 11:05 AM
intezn
Nov 10, 2002 10:47 AM
