i need some help
Old Jan 2, 2005 | 06:33 PM
HondaCivicSiR1's Avatar
Default i need some help
i just want to know is a walbro 255lph fuel pump ok to run on stock injectors and stock fpr also my injector on 1 on leaking some gas what would make it do that. also is a stock cat not good to use when you have a 4-1 header. this my ef9 that im talkn about so if anyone can help me please do so thank ahead of time.
Old Jan 2, 2005 | 06:44 PM
HR-1320's Avatar
Default Re: i need some help (HondaCivicSiR1)
The fuel pump is fine put it in. As for the injector there is a seal at the fuel rail and one in the manifold make sure that there in good shape . If not it can leak . Inspect the injector as well make sure nothings cracked or broken. As for the cat I would leave it unless your running turbo , nitrous or your motor is sick. If its still stock the sound diff isn't worth the 1hp you may get out of it.
Old Jan 2, 2005 | 06:59 PM
Default Re: i need some help (2.0Coupe)
yo thanks nice to get some in put from someone i know peace out see ya around
Old Jan 2, 2005 | 07:07 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0Coupe &raquo;</TD></TR><TR><TD CLASS="quote">The fuel pump is fine put it in. </TD></TR></TABLE>
if you have a fuel pressure gage and a adjustable fpr.
Your fuel pressure will go up since the pump supplies more fuel. The return orifice in the stock fpr will create a restriction in the fuel return line. If you don't already have one, get an adjustable fpr and gage. I had to replace my b&m fpr with an aem fpr to get decent fuel pressure at idle.
2kgsrt
Apr 1, 2010 06:25 PM
cousin_ed
Aug 13, 2009 05:47 PM
Metal Head
Dec 20, 2006 10:01 PM
Ruben19
Jan 27, 2006 12:48 PM
trooper0641
23
Apr 6, 2005 12:51 PM
