PLEASE HELP IDING A TRANNY
Old Jan 2, 2005 | 03:58 PM
1.8turbolsvtec's Avatar
Default PLEASE HELP IDING A TRANNY
just got a b series tranny i was told that it was a ls how can you tell with no letters or numbers on the out side of the tranny
thanks to all who look and try to help
Old Jan 2, 2005 | 06:29 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: PLEASE HELP IDING A TRANNY (1.8turbolsvtec)
if you are mechanically inclined enough, then open it up and count some teeth. with it in the car, check the rpms vs speed. besides that there isn't much you can do. assume it's a ls cuz it's not like you can be getting anything below a ls spec tranny...anything above, such as a gsr or b16, and you are lucky unless you opted for the ls specs.
Old Jan 2, 2005 | 09:02 PM
Default Re: PLEASE HELP IDING A TRANNY (not so civic)
thanks verymuch
Old Jan 3, 2005 | 07:07 AM
if you do open it up or have someone open it up, i have teeth counts for all the gears. or you can just do a little math if you got the ratios. of course, there are quicker ways to tell by looking at the line code at the end of the gears.
pliskin679
Aug 11, 2010 10:46 PM
payneth
Oct 29, 2005 12:39 PM
GuateskateVti
Sep 21, 2005 11:11 AM
WeaKSouL
Jun 16, 2004 04:15 PM
white_eg
Sep 8, 2003 03:36 PM
