How to reset engine light on 2000 accord
Old Jan 7, 2002 | 07:17 PM
89civicdx's Avatar
Default How to reset engine light on 2000 accord
How do you reset the engine light on 2000 accord?
yes I already used the search function
[Modified by 89civicdx, 8:18 PM 1/7/2002]
[Modified by 89civicdx, 9:24 PM 1/7/2002]
Old Jan 7, 2002 | 09:37 PM
ArchAngel Sabastian's Avatar
New User
Default Re: How to reset engine light on 2000 accord (89civicdx)
err the check engine light??
well its a 2000 so hook that heavy **** up to a scanner find the problem fix it and then reset the ecu or have the scanner reset it.
Old Jan 8, 2002 | 03:59 PM
89civicdx's Avatar
Default Re: How to reset engine light on 2000 accord (Sabastian)
No the question is HOW do you turn off the light? What is the method used?
Old Jan 10, 2002 | 06:55 PM
yolooky's Avatar
you must use a scan tool to reset light
Old Jan 10, 2002 | 10:46 PM
WordToYoMotha's Avatar
Do u mean engine light or the maintaneance required light?
Old Jan 17, 2002 | 06:05 PM
supadupamikey's Avatar
Default Re: How to reset engine light on 2000 accord (WordToYoMotha)
How do you reset the maintenance required light? Its quite cold and I haven't got a chance to crawl under my dash and I've only had the car a week and been hustling between college and working.... but anyways...
my gsr has a button right under the dash and i push it in... i felt around on my accord but couldn't find anything.
Old Jan 18, 2002 | 09:47 AM
exoxe's Avatar
Default Re: How to reset engine light on 2000 accord (lilmikey77)
I believe you hold down the reset button for 10-15 seconds while the key is in the ignition but in the OFF position, then after 10-15 seconds you turn your key (finger still on reset button) to the first position for about 5 seconds and then let go of the reset button. See if that works.
Old Jan 19, 2002 | 09:57 AM
Default Re: How to reset engine light on 2000 accord (exoxe)
I called the dealer yesterday and asked the parts department... here's what he told me. Evidently, it worked. My light isn't flashing anymore
With the car off, key off, etc... Push and hold down the trip reset button, turn the key just so the dash lights come on, keep holding the trip reset button down, the maintenance required light will flash several times and then it will go off, once the light goes off, release the trip reset button, then turn the key off. voila!
Old Jan 21, 2002 | 03:58 AM
urbanlegend21's Avatar
New User
make sure this gets archived, thanks for sharing lilmikey
Old Jan 21, 2002 | 05:26 AM
Default Re: How to reset engine light on 2000 accord (urbanlegend21)
Old Jan 21, 2002 | 01:05 PM
Accord1999's Avatar
New User
Resetting the Maintenance Light is somewhere in our owners manual. I read it long time ago.
KM128
May 14, 2014 02:12 PM
Importn2oRacer
May 12, 2007 07:05 PM
evd
Nov 18, 2005 05:27 PM
rtsab
Jan 17, 2003 02:38 PM
