Camber kits
Old Jan 7, 2002 | 07:16 PM
29psiHybrid's Avatar
Default Camber kits
Ok I've needed a camber kit for a long time and I've finally decided to get one. So what does everyone recommend? I like the Skunk 2 upper control arms but they're kind of expensive. Give me your input.
Old Jan 7, 2002 | 07:23 PM
Hybrid ctr's Avatar
Default Re: Camber kits (9psiHybrid)
Skunk2
they aren't $$$$ compared to King Motorsports upper control arms
Old Jan 7, 2002 | 07:28 PM
d0nkeyxPunch's Avatar
Banned
Default Re: Camber kits (Just Bored)
Are camber kits hard to install?
Old Jan 7, 2002 | 08:29 PM
94civicx's Avatar
New User
Default Re: Camber kits (FastxCivic)
no, I installed my camber kit in about 1 hr all the way around
Old Jan 7, 2002 | 09:28 PM
Maxi's Avatar
Default Re: Camber kits (94civicx)
I have a 93 CX hybrid which I road race and I definitely recommend the Skunk2 front camber kit. They're actually the cheapest upper control arm replacement kit on the market that I know of and they work extremely well (ie. offer a wide range of adjustability). For the rear, the Ingalls kit works fine and is inexpensive. However, the front Ingalls kit is a pain in the *** to adjust and doesn't offer a wide enough range of adjustment if you're serious about dialing in some negative camber for the race track or taking out a lot of camber if you've seriously slammed your ride and don't want to wear out your street tires.
Old Jan 7, 2002 | 09:48 PM
2000si's Avatar
do the skunk camber kits (front) come with ball joints?
Old Jan 8, 2002 | 12:41 AM
Gump's Avatar
here is a really cheap camber kit for the rear and it works really well http://www.geocities.com/kingmantis81/rearcamber.html
Old Jan 8, 2002 | 12:42 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Camber kits (xlr8 si)
Skunk2 kit is the best I've found!!
Yes, they come with the ball joint too. (whatta deal)
I got mine for $225 shipped.
Old Jan 8, 2002 | 06:00 AM
Default Re: Camber kits (B18C-EJ1)
$225? where at?
Old Jan 8, 2002 | 06:35 AM
RyanR's Avatar
Hit up Frank Lin. He sells them for $200. His username on the board is frank@b16a.com.
MugenEg6's Avatar
Ingalls= 130 bucks shipped
Old Jan 9, 2002 | 05:01 PM
hondafrk's Avatar
Default Re: Camber kits (MugenEg6)
ingalls camber kits are tricky, You have to know how much you lower your car before you order the kit. Get an alignment done and find out what you need. I made the mistake of ordering the 3 degree kit for my eg when i lowered it 2.5" and with the adjustments all the way neg my front camber was at -.1degrees . I originally wanted to get at least -2.0 degrees. I put the stock bushings back in and i dropped it to and even -1.5 on both sides figure that out. Get the control arms Less bullshit
JRTegman987
Suspension & Brakes
Oct 22, 2006 11:38 PM
lsvtec_DA
Feb 25, 2004 09:59 PM
Sandor
Nov 17, 2003 09:01 AM
Jason C SBB
Sep 8, 2003 08:09 AM
JeremyL
Apr 12, 2003 05:25 PM
