Grounding large pieces ?
Old Jan 2, 2005 | 12:26 PM
RCautoworks's Avatar
Default Grounding large pieces ?
Just wondering what you guys are doing ? I have an exhaust here that needs to be welded but the grounding clamp will not go around the piping and there is nothing else for it to clamp on to.
Old Jan 2, 2005 | 12:36 PM
dk-fabrications's Avatar
Default Re: Grounding large pieces ? (90blackcrx)
lay the piece that you need to weld on a metal table and ground the table
make sure the metal is down to metal not painted
clamp it in a place on the edge where its just metal no paint and you will be fine
good luck !!!
Old Jan 2, 2005 | 01:00 PM
fabnewb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering what you guys are doing ? I have an exhaust here that needs to be welded but the grounding clamp will not go around the piping and there is nothing else for it to clamp on to.</TD></TR></TABLE>
i usually clamp the inlet or outlet. Or flange, or anything else. or just clamp on the table that you are welding on.
Old Jan 2, 2005 | 02:35 PM
Default Re: Grounding large pieces ? (fabnewb)
Don't have a metal table at the moment, but that is gonna be my next project. And I could not clamp inside the pipe because the only place was by the cat and tip and I did not feel that it would of been a good enough ground.
Old Jan 2, 2005 | 02:38 PM
Kookz's Avatar
Resident Vagabond
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Don't have a metal table at the moment, but that is gonna be my next project. And I could not clamp inside the pipe because the only place was by the cat and tip and I did not feel that it would of been a good enough ground.</TD></TR></TABLE>It's amazing what you can accomplish if you try. If you cleaned the metal it will be fine.
Old Jan 2, 2005 | 02:42 PM
snoochtodanooch's Avatar
Default Re: Grounding large pieces ? (Kookz)
how about a bolt into the cat, that should work fine
Old Jan 2, 2005 | 02:53 PM
turbo gli's Avatar
Default Re: Grounding large pieces ? (snoochtodanooch)
or how about the exhaust hanger?? muffler tip .. a bolt .. hella places
Modified by turbo gli at 12:10 AM 1/3/2005
Old Jan 2, 2005 | 03:13 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Grounding large pieces ? (turbo gli)
yea, my fab guy just ground his table
Old Jan 2, 2005 | 05:11 PM
TeamNextGenChris's Avatar
at work,when welding the attachment plates for gooseneck hitches,we just stick the ground clamp onto one of the spring perches.works great,even all the way on the other side of the car.i know that doesn't apply to your case,but my point is if you can find something even remotely close,and connected to your part ground-wise,you're fine.in the past i've also tacked the ground clamp to the piece i was welding-jut don't go crazy and make a tack you can't easily get to and knock off with a wizz wheel.
Chris
Old Jan 2, 2005 | 07:15 PM
HamiltonRex's Avatar
Default Re: Grounding large pieces ? (TeamNextGenChris)
anywhere possible that is even REMOTLY attached to it. Just spark it if it arc's its good and weld
Old Jan 2, 2005 | 11:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">how about a bolt into the cat, that should work fine</TD></TR></TABLE>
Thats what I ended up doing, well I wedge it in between the bolt and the pipe. And since it was touching the pipe it was good to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kookz &raquo;</TD></TR><TR><TD CLASS="quote">It's amazing what you can accomplish if you try. If you cleaned the metal it will be fine.</TD></TR></TABLE>
Of course I tried first, what do you think I just looked at the freakin exhaust and said uhhhhh duh come on now. It was not really for this project but just to know in the future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo gli &raquo;</TD></TR><TR><TD CLASS="quote">or how about the exhaust hanger?? muffler tip .. a bolt .. hella places
Modified by turbo gli at 12:10 AM 1/3/2005</TD></TR></TABLE>
No hangers were on there, the muffler tip was to far away and is not metal on the one side, its coated with something.
RACEPAK
Welding / Fabrication
16
May 7, 2005 07:34 PM
s1ngle
Feb 10, 2005 03:16 PM
JMD
Aug 12, 2004 10:46 PM
t o m
12
Mar 6, 2004 02:43 PM
boostedsi1
Aug 6, 2003 09:06 AM
