Help with brake removal please!
Old Jan 2, 2005 | 11:57 AM
kidaniel's Avatar
Default Help with brake removal please!
Well I got the brake rotor off and everything but I just can't seem to get that center piece out because I broke a stud and I am replacing it.
I already removed the 36mm lug in the center.
I tried pulling it off but I decided to ask someone before I keep on trying and end up screwing it up.
BTW...no thats not my brakes, I just borrowed it to show you which part I couldn't get off.
(I have a 5th gen)
Thanks!
Daniel
Old Jan 2, 2005 | 12:23 PM
kidaniel's Avatar
Default Re: Help with brake removal please! (Chase)
Maybe you should try reading...
I'm not asking to get the rotor off.
I am trying to fix my studs and I already have the rotor off.
Trying to get the center peice that is seperate from the rotor.
I have a 5th gen so it is a bit different than the picture.
Old Jan 2, 2005 | 12:28 PM
edd001's Avatar
Default Re: Help with brake removal please! (kidaniel)
if i am correct you need to remove the hub in order to replace a wheel stud.
if this is the case you will probably need to use a slide hammer and just keep trying to get it of that way. it may be difficult as you have to separate the bearing.
Old Jan 2, 2005 | 12:59 PM
kidaniel's Avatar
IM I just got
Chase (1:35 PM 1/2/2005): i misread your post
Chase (1:36 PM 1/2/2005): **** yourself kid
hahaha....thats real mature.... do you feel better now e-thug??
thanks for the help edd001
Old Jan 2, 2005 | 01:24 PM
sasha_mitchell's Avatar
so then you have the one with the rotors that are pressed on?!? i dont think thats a 5th gen....
Old Jan 2, 2005 | 01:31 PM
kidaniel's Avatar
IM I just got
hahaha....thats real mature.... do you feel better now?
Old Jan 2, 2005 | 01:32 PM
kidaniel's Avatar
Default Re: Help with brake removal please! (Untuned_hatch)
The picture isnt a 5th gen but i circled the area that i need to get off for the 5th (just to kind of give you an idea)
Modified by kidaniel at 3:11 PM 1/2/2005
Old Jan 2, 2005 | 01:46 PM
flip1199's Avatar
it all needs to come off. and take it to a machine shop to get the hub pressed out.
johnny090881
May 28, 2010 07:41 AM
LOWLIFEHATCH
Sep 30, 2004 01:14 PM
Regular Series
Aug 15, 2004 08:04 AM
Drano81
Jan 21, 2003 02:00 PM
see_fu
Sep 9, 2002 03:18 PM
