Tire Size Concerns
Old Jan 2, 2005 | 11:29 AM
Default Tire Size Concerns
Will a 235/40-18 tire fit on a 18x7.5 offset +45 wheel on a 98-02 Accord?
Old Jan 2, 2005 | 11:32 PM
Default Re: Tire Size Concerns ("Hites")
bueller?
Old Jan 3, 2005 | 09:34 AM
ericjackson's Avatar
i just called a place, anyways for a 6th gen, its gonna be a little wide, but it will work. you MAY have to run a spacer if you have anyprobs though
Modified by ericjackson at 12:48 PM 1/3/2005
Old Jan 3, 2005 | 07:20 PM
iand415's Avatar
i had 225/40/18 tires with the same rim size but im not sure what my offset was, i think i was about +45. anyway, they fit fine but my rear tires would rub on my fenderwell everytime i hit a bump or a dip on the street. the front rims fit fine without any rubbing. i guess it depends on how low your car is also, i have a 2.5 drop all around. i hope this helps
Old Jan 4, 2005 | 05:57 PM
Default Re: Tire Size Concerns (iandeezy415)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iandeezy415 &raquo;</TD></TR><TR><TD CLASS="quote">i had 225/40/18 tires with the same rim size but im not sure what my offset was, i think i was about +45. anyway, they fit fine but my rear tires would rub on my fenderwell everytime i hit a bump or a dip on the street. the front rims fit fine without any rubbing. i guess it depends on how low your car is also, i have a 2.5 drop all around. i hope this helps</TD></TR></TABLE>
i probably will only drop it 1", 2" at the very very max.
Old Jan 4, 2005 | 06:38 PM
98carbonaccord's Avatar
i have 18x7.5 with +45 offset and 225/40/18 tires, no rubbing issues at all
pics: http://www.cardomain.com/id/98carbonaccord
Old Jan 4, 2005 | 07:01 PM
Default Re: Tire Size Concerns (98carbonaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98carbonaccord &raquo;</TD></TR><TR><TD CLASS="quote">i have 18x7.5 with +45 offset and 225/40/18 tires, no rubbing issues at all
pics: http://www.cardomain.com/id/98carbonaccord</TD></TR></TABLE>
me either, with an 1.5 in drop. not even close
Old Jan 4, 2005 | 07:03 PM
Default Re: Tire Size Concerns (ericjackson)
but i hear, with a 2in, you might wanna run 35series
Old Jan 4, 2005 | 10:24 PM
iand415's Avatar
yeah that would be a good idea too, just gotta be careful with those nasty pot holes. i cracked 2 of my rims cuz i hit a deep pot hole on a freeway on-ramp
Old Jan 5, 2005 | 11:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericjackson &raquo;</TD></TR><TR><TD CLASS="quote">but i hear, with a 2in, you might wanna run 35series</TD></TR></TABLE>
id only have a 35 series tire if the width was 305 or greater. just not enough sidewall on a 35.
Old Jan 5, 2005 | 08:06 PM
hummm, you lost me. i dont think a 305 would ever fit. i was talking about how tall the tire is. ive heard if you lower 2in. you will have to run say a 225/35/18 rather than a 225/40/18.
aznbigman
May 1, 2008 11:14 PM
aln2590
Aug 6, 2007 09:16 AM
ezol
Jan 13, 2007 02:52 AM
RedHondaSi
Dec 25, 2003 08:54 PM
MintyDip
Jul 25, 2002 02:27 PM
