K20 into 2001 civic
Old Jan 2, 2005 | 11:11 AM
kc90hb's Avatar
Default K20 into 2001 civic
just a quik question for ne one out there that has done a k20 swap into a 2001ish civic four door. Curious who did it, if you have enjoyed the results and around how much you spent. Also if you have a good idea of where i could get it done or pick up a k20 i'd appreciate it. thanks this is for a friend... he cant buy a different car and kind of wants to buil up this one...
Old Jan 2, 2005 | 02:02 PM
MidoriEK4's Avatar
Default Re: K20 into 2001 civic (kc90hb)
is this a em chasis?
Old Jan 2, 2005 | 02:41 PM
MugenRacerX's Avatar
Default Re: K20 into 2001 civic (MidoriEK4)
I belive this is still on topic does anyone know the weight of the k20a with its tranny? Call hasport and see if they supply a mount kit for that swap,unless you are crafting your own mounts I dot know of another company that would have them.I do know they have a sub harness that should help with the wiring madness this swap requires.
Old Jan 2, 2005 | 06:55 PM
tfnaaf's Avatar
http://www.7thgencivic.com/for...41122
Old Jan 3, 2005 | 06:12 PM
ShaunRR's Avatar
HT White Ops
Community Builder
User K20whitevic likes his, but he has a coupe not a four dour.
Old Jan 3, 2005 | 08:17 PM
kc90hb's Avatar
Bump...
Old Jan 11, 2005 | 08:01 PM
kc90hb's Avatar
bump.. i see people want him to swap it...
Old Jan 12, 2005 | 08:26 AM
Dsm634's Avatar
LOUD NOISES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kc90hb &raquo;</TD></TR><TR><TD CLASS="quote">bump.. i see people want him to swap it...</TD></TR></TABLE>
Definitely.
Old Jan 12, 2005 | 08:27 AM
aznboysrfr's Avatar
there is a guy on 7thgencivic.com who has a blue sedan ... he's from canada, but I don't remember his name -_-;;
Old Jan 12, 2005 | 05:04 PM
keithg's Avatar
Here is a link to info on Hasports own 2001 Civic EX "Type-S" four door from Car and Driver magazine September 2003.
http://www.caranddriver.com/ar...er=11
Old Jan 12, 2005 | 06:40 PM
kc90hb's Avatar
Default Re: K20 into 2001 civic (keithg)
thanks
Old Jan 19, 2005 | 10:08 PM
k20whitevic's Avatar
I'm pretty sure you started a thread about this over on mnsportcompacts.net. I remember a person with the same sn as you, asking this question.
Finished product.
Modified by k20whitevic at 7:22 AM 1/20/2005
Old Jan 20, 2005 | 12:00 PM
kc90hb's Avatar
Default Re: K20 into 2001 civic (k20whitevic)
lol yea i did, im a member of both great sites, i like to get opinions and facts and people that have had experience in the field etc... thanks for the post
Old Jan 22, 2005 | 01:18 PM
kc90hb's Avatar
bump..
Old Jan 22, 2005 | 06:04 PM
ShaunRR's Avatar
HT White Ops
Community Builder
K20a.org
Old Jan 25, 2005 | 03:33 PM
kc90hb's Avatar
Default Re: K20 into 2001 civic (rochesterricer)
TIGHT!
Old Jan 26, 2005 | 08:37 AM
K-Series.com as well.
Old Jan 27, 2005 | 03:59 PM
kc90hb's Avatar
Default Re: (k20whitevic)
a little off topic, but how can u put pics on threads? im sorry im dumb
Old Jan 27, 2005 | 07:00 PM
StorminMatt's Avatar
If a K20 swap is a little rich for you, you could always do a K24 swap. This won't get you the same kind of power as a K20 (160HP vs 200HP). Unless, of course, you get the TSX motor (which will also be expensive). On the other hand, it will give you more torque (166ft-lb vs 142ft-lb). And because this motor is used in a MUCH larger number of vehicles sold than the K20, you can certainly pick one up MUCH cheaper.
Old Feb 3, 2005 | 07:10 PM
kc90hb's Avatar
Default Re: K20 into 2001 civic (StorminMatt)
i thought k24's mainly only went into tsx's?
Old Feb 3, 2005 | 07:16 PM
4drmadness's Avatar
K20 would be a sweet swap and alos on the diff side since you would have it going in a 4dr.
Let us know what you do and good luck.
Old Feb 4, 2005 | 08:33 AM
keithg's Avatar
The K24 is used in all the current Accords, CRVs and Elements. Honda has sold more than 200,000 of them in the U.S. since 2002 (CRV) and there are there are hundreds of them for sale right now on http://www.car-part.com . The Accord and Element engines have EGR and the CRV engine does not. I just looked on http://www.car-part.com and there are 2002 up CRV engines as low as $750 with 10k miles and 2003 up Accord motors as low as $500. Brian Hasty at http://www.fastbrakes.com has one in an EG with Hasport mounts and the stock K24 Accord motor with I.H.E. makes 160 whp and 160 wtq on a dyno-jet. It is a blast to drive.
Modified by keithg at 5:46 PM 2/4/2005
Modified by keithg at 5:53 PM 2/4/2005
Old Feb 7, 2005 | 01:25 PM
kc90hb's Avatar
i heard indoensiaż might be making a 2 or 4dr with a k20 stock, right hand drive...
Old Feb 7, 2005 | 02:51 PM
4 door, with a K20A3.
Old Feb 7, 2005 | 03:38 PM
aznboysrfr's Avatar
^^ detuned k20a3 at that.
