white smoke?
Old Jan 2, 2005 | 10:03 AM
sol_tuner's Avatar
Default white smoke?
my del sol puffs white smoke when i accelerate. Could this be a blown head gasket?
Old Jan 2, 2005 | 10:08 AM
Luserkid's Avatar
Default Re: white smoke? (sol_tuner)
Could be anything.
When does it do it, all the time, only in the morning when its cold, only after you take a crap? when?
Old Jan 2, 2005 | 10:09 AM
civictildeath's Avatar
depends only like when you rev it up?? does it disappear quickly or hang around for a minute
Old Jan 2, 2005 | 10:20 AM
sol_tuner's Avatar
Default Re: white smoke? (Luserkid)
it tends to do it all the time when i give it alot of gass it does it alot
Old Jan 2, 2005 | 10:21 AM
that sux
sol_tuner's Avatar
Default Re: white smoke? (civictildeath)
yea when i rev it then it goes away
Old Jan 2, 2005 | 10:25 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol_tuner &raquo;</TD></TR><TR><TD CLASS="quote">it tends to do it all the time when i give it alot of gass it does it alot </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol_tuner &raquo;</TD></TR><TR><TD CLASS="quote">yea when i rev it then it goes away</TD></TR></TABLE>
That makes no sense, when you give it gas its there but when you rev (which is also giving it gas) it goes away? Care to explain?
Old Jan 2, 2005 | 10:28 AM
Old Jan 2, 2005 | 10:31 AM
onePOINTsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>ahahahaajajaj.....breath...ahahahahahah
Old Jan 3, 2005 | 02:47 PM
sol_tuner's Avatar
na what i ment was at idle its fine when i hit the gas it smokes then goes away as soon as the rpms go down. srry for the misunderstanding
Old Jan 3, 2005 | 03:14 PM
philosofy1's Avatar
you probably have a bad oil leak. dont know exactly what your condition is but i once has a broken piston ring and i had white smoke when i drove. my motor was burning oil.
you should take it to a mechanic and get it checked.
Old Jan 3, 2005 | 03:45 PM
jayare05's Avatar
Default Re: white smoke? (philosofy1)
check ur oil level. then check the antifreeze.. u should get a good idea of what it is after doing that
Old Jan 3, 2005 | 06:00 PM
sol_tuner's Avatar
ok thanx ill have it looked at i did a compression test and its between 110 and 120 all cylinders is if a ring was blown wouldnt it be lower on one cylinder? but thanx ill have it looked at in the morning
Old Jan 3, 2005 | 06:55 PM
Daniel san's Avatar
your head gasket is gone.
how many miles do you have on that motor ?
Old Jan 4, 2005 | 05:44 PM
sol_tuner's Avatar
Default Re: white smoke? (Daniel san)
121394 miles
Old Jan 4, 2005 | 05:50 PM
germz's Avatar
to check if your head gasket is blown...start up your motor and open the radiator cap to see if theres bubbles in the coolant.
Old Jan 4, 2005 | 06:13 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel san &raquo;</TD></TR><TR><TD CLASS="quote">your head gasket is gone.
Damn..
Where the **** did it go?
Old Jan 4, 2005 | 06:18 PM
92jdmhatch's Avatar
Default Re: white smoke? (Jimmy)
Old Jan 4, 2005 | 06:24 PM
ABK's Avatar
ABK
Default Re: white smoke? (92jdmhatch)
holy fucken '04-'05 batman these people just come up with **** out of their ***.
Simpe way to check you got coolent in your oil, or oil in your coolant?
Your overflow tank gets overflown?
Your car overheats?
You can do a compression/leakdown test
It's prolly doing it because it's just cold and humid outside, relax.
And no burning oil will not make white smoke. Water/coolant will do that.
Old Jan 31, 2005 | 12:31 PM
eGeeHaTcH's Avatar
Default Re: white smoke? (ABK)
if the white smoke hangs around for a bit, what does that mean?
Old Jan 31, 2005 | 12:45 PM
poke's Avatar
Default Re: white smoke? (eGeeHaTcH)
coolant. does your car heat up at all?
Old Jan 31, 2005 | 12:48 PM
99hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">
i thought it was cold and dry
Old Jan 31, 2005 | 01:05 PM
huntarrr's Avatar
Default Re: white smoke? (99hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hatch &raquo;</TD></TR><TR><TD CLASS="quote">
i thought it was cold and dry</TD></TR></TABLE>
actually, when its cold out there is more humidity. its only when you heat the air up (like in your house) is when it gets dry
Old Jan 31, 2005 | 01:12 PM
rass1313's Avatar
listen to ABK!!! compression/leakdown test will tell u exactily what it is.....
FYI.....burning oil= blue .........white=water/antifreez
Old Feb 1, 2005 | 02:29 PM
88crx-si's Avatar
DAMN! my car just started doing this.
i drove to work on the freeway, got off the freeway, idle was weird,
turned off car, started it again, sounded like it was a WRX like it was
misfiring, checked plugs & wires, then left the car alone.
after about an hour it was FINE. no nothing. it was good all the way home.
TODAY...going home from school, got off the freeway, half way home,
THEN got a bad idle and that same misfiring with white smoke...
what is it? its pissin me off. it scared me at first because i thought i
had a blown gasket but it wasnt overheating and the oil/coolant was fine..
