can i run 17x8 whees?
Old Jan 2, 2005 | 08:06 AM
xxmaxhardcorexx's Avatar
Default can i run 17x8 whees?
on a 5th gen accord? i'm guessing i cant go any wider than a 225 tire?
has any one had this set up.
thanks
Old Jan 2, 2005 | 08:43 AM
uncle_el's Avatar
Default Re: can i run 17x8 whees? (xxmaxhardcorexx)
i've talked with some people that have vip style cars (large rwd sedans,slammed, deep dish wheels tucked), and here is the information i received:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
With a little bit of extra work, you can actually fit a lot wider and lower offset wheels on a fwd car than most people would think. For example, I had always been told that you'd be lucky to fit anything more than a 7.5", +32mm on a honda civic... well, here's some 17x8", +25mm we put on a friend's civic for kicks:
I would reocmmend checking out stylewagon magazine if you're near a japanese bookstore for ideas too, because that's where you'll see most of the crazy fixed up fwd cars, including accords every so often...
the best way to determine how wide/low offset you can go is to take your existing setup, and measure the clearance that you have now, and go from there. Try and see how much room you have between the outer edge of your current wheels/tires and about a few mm beyond the middle of your fender lip. I'm willing to bet that you've got AT LEAST an inch. so if you rolled your fender lips flat... and ran even just another deg of negative camber all around, you could probably fit something along the lines of a 17x8", +20mm or so... just to give you an idea...</TD></TR></TABLE>
you'd be pushing it to run wheels that wide... you'd have to be willing to run a large degree of camber, and likely have to roll/cut your fenders.
in short, it can be done, with modification to both the suspension and body. in other words, you won't be able to buy those rims, slap 'em on your car, and call it a day. well, i guess you could, but you'd likely run into some issues.
sorry, no pics of a wheel that wide on an accord.
Old Jan 2, 2005 | 08:53 AM
that looks awsome on that civic,
here is a pic of ******* car from jhp.. i think those are 16"x8 blitz.
but i'm looking to run a 45 series on 17"s x 8 hopefull with no rubbing on the A-arm or the fender...??? any one got more pics.
Old Jan 2, 2005 | 09:08 AM
Nick M's Avatar
you would probably have to roll ur fenders to get them to fit
i dont see the benefit
Old Jan 2, 2005 | 01:00 PM
Default Re: can i run 17x8 whees? (Evil Nick M)
more tire on the ground. but if i halft to roll my fenders for get it.
it just seems like it is possable.
Old Jan 2, 2005 | 01:52 PM
Showoff's Avatar
I Have 18x7.5 no problem in a accord, i remember an accord with 18x8 with 225/40/18 he rolled his fenders..but why so wide ? just asking ? cuz most know we aint too lucky to put wide rims in our fwd cars, something rwd do have on us to put wide rims. just my saying i dunno
P.S is your car dropped ? if so how much ?
Old Jan 2, 2005 | 02:42 PM
Default Re: can i run 17x8 whees? (Showoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Showoff &raquo;</TD></TR><TR><TD CLASS="quote">I Have 18x7.5 no problem in a accord, i remember an accord with 18x8 with 225/40/18 he rolled his fenders..but why so wide ? just asking ? cuz most know we aint too lucky to put wide rims in our fwd cars, something rwd do have on us to put wide rims. just my saying i dunno
P.S is your car dropped ? if so how much ? </TD></TR></TABLE>
it's not for show or anything like that, more for track reasons i know i can run a 7.5 with a 225 tire but i would rather run an 8 this way there is more tire being used on a 225.
Old Jan 2, 2005 | 02:52 PM
syclone's Avatar
it's not really of matter what how wide you want to go.. it's a matter of how much work you're willing to do to fit the size you want..
the tires on my accord are flush with the outter fender, but i had to cut the lip to accomodate it..
Groovinator
Honda Fit
16
Jul 10, 2009 06:48 AM
vector248
Honda Civic (2001 - 2005)
May 15, 2008 12:11 PM
JDMTURTLE
Jul 31, 2007 12:03 PM
Avaya22
Apr 16, 2006 02:05 PM
kriptik
May 26, 2004 04:53 PM
