gsr cams in b16 what timing map to use
Old Jan 2, 2005 | 07:59 AM
goose21's Avatar
Default gsr cams in b16 what timing map to use
I'm planning on putting gsr cam's in my b16. But can i still use the b16 timing map. Or should i use a gsr timing map as a base, i have hondata.
Can someone give me some info on this.
thanks Jose
Old Jan 2, 2005 | 08:41 AM
quicksol95's Avatar
Default Re: gsr cams in b16 what timing map to use (goose21)
yes you can
the gsr cams are not that much bigger then the b16 cams
Old Jan 2, 2005 | 08:52 AM
goose21's Avatar
Default Re: gsr cams in b16 what timing map to use (slow90hatch)
But don't they have a other point of were they have max timing. With my b16cams that is 6500rpm. And the gsr timing map look realy different
Modified by goose21 at 10:10 AM 1/2/2005
Old Jan 2, 2005 | 09:12 AM
5thgencivic's Avatar
You are still running a B16 just different cams. I would start off the B16 map. IMO. Unless your setup differs a lot from a stock B16(bigger bore, etc)
Old Jan 2, 2005 | 09:28 AM
Sprockets's Avatar
Sorry to jack your thread, but what is the advantage of using GSR cams on a B16a?
Old Jan 2, 2005 | 09:55 AM
goose21's Avatar
Default Re: gsr cams in b16 what timing map to use (5thgencivic)
Its a b16 bootom end 9;1 comp
itr valvetrain
gsr cams
itr Intake mani and TB
so i should just go with the b16map
Old Jan 2, 2005 | 10:20 AM
quicksol95's Avatar
yes start from there then tune
Old Jan 2, 2005 | 10:34 AM
goose21's Avatar
Ok, thanks for your help
Old Jan 2, 2005 | 11:18 AM
Sprockets's Avatar
Thanks for ignoring me.
Old Jan 2, 2005 | 11:30 AM
goose21's Avatar
Default Re: gsr cams in b16 what timing map to use (B16A Grenade)
the reason i'm going with the gsr cams is because the have more lift than b16 cams but do not have to much duratation. Thats wy the are better and make more hp's(turbo likes lift no duratation). I've read about 10 to 30hp this is what i read correct me if im wrong
But al of this you've could have read just like me if you just used the search button and looked for "gsr cams" Thats wy i think they ignore you.
That question gets asked 10 times a day
But i hope i have answered your qeustion
Modified by goose21 at 12:42 PM 1/2/2005
Old Jan 2, 2005 | 06:47 PM
Sprockets's Avatar
You answered my question, I appreciate it. Very rarely do I ask a question. 99% of the time I spend searching through the archives. I've read about other people using gsr cams, but wasn't sure if it was to raise the redline or not. It was just a simple question, and no, it doesn't get asked 10 times a day.
sick93sol
Apr 10, 2009 09:45 PM
Team PHATBOYZ
Mar 30, 2009 12:02 PM
94b16teg
Sep 24, 2006 09:35 AM
xtreme412
28
Jul 22, 2006 09:20 PM
deca
Mar 23, 2006 02:01 PM
