my doors won't open!
my trunk will open
when i try to use the keyless entry, it seems as if my car unlocks, but hten locks itself again, i tried to look at it, but nothing happens, it just makes the noise that it's unlocking but then locking YET nothing happens
are you sure its your car?
j/k, yea i'd pour hot water on the locks and pour some down between the door and the pilar. if that doesnt work, i'd probably just crawl in through the trunk and start the car and let it run for 10 minutes or so with the heat on. maybe drive to where you have to go and it should be ok by then. i had a similar issue once but the other way around... my door wouldnt close. after i opened it the latch froze and i ended up driving to work holding my door so it wouldnt swing open. i actually got it to latch as i was pulling into work.
also, are you sure it isnt some sort of security thing? my neighbor's old accord had its window broken and it went into some mode where the doors wouldnt unlock and the car wouldnt start.
no, it's no security thing i haven't done anything that has to do with security to my car but get an auto lock for it.
and yessss the car is miiiine that's why ican't do much to it, because i spent my money on getting it myself ;X
or they sell those keychain things that use batteries, and a small metal prong comes up and you put that into your keyhole...
things that sound dirty but aren't
TylerC161
Apr 11, 2008 03:16 PM
