LS/GSR Swaybars on EG8
Old Jan 2, 2005 | 02:43 AM
CRAZYEG9's Avatar
Default LS/GSR Swaybars on EG8
I'm thinking about getting stock sway bars from a 94-01 Ls, or GSR, Integ. I believe they're 22mm front 13-14mm rear. I want stock ones because I don't want no crazy thick aftermarkets or type Rs since they can do chasis damage. Do you guys think this is a good Idea, and will I need the beaks kit with OEM LS/GSR bars. My car is an eg 4dr LX, non swaybar equipped.
Old Jan 2, 2005 | 05:40 AM
ADN_pt's Avatar
Default Re: LS/GSR Swaybars on EG8 (CRAZYEG9)
Helo.. I have an EG6 with 21/15mm sways and i'm going to put the integra's sways as soon as i find out if i can put the integra subframe not to damage the chassis, as you said.
A sway bar(ok or anti-sway bar) will help you a lot reducing the lazy rooling you must have. Try those sways first, and if later, you think they aren't enough go for larger diamater sways.. my opinion.
PS- before changing sways i would change shoks and springs.
PreyStayShun
May 22, 2011 01:01 PM
HondaGSX
Jan 23, 2007 07:51 PM
Drian
Jan 2, 2006 08:47 AM
Nifty
Aug 5, 2004 03:41 PM
gmagnan
Apr 20, 2002 02:43 PM
