how do you manipulate clutch and gas pedal for 1st gear drag?
Old Jan 2, 2005 | 12:04 AM
yeegsr's Avatar
Default how do you manipulate clutch and gas pedal for 1st gear drag?
how do you manipulate clutch and gas pedal for 1st gear drag take off?
Old Jan 2, 2005 | 12:23 AM
DC2 BoZz's Avatar
Default Re: how do you manipulate clutch and gas pedal for 1st gear drag? (yeegsr)
what i do is since i have LSD i tack it up to 2500 to 3000 and i pop the clutch..the LSD reduces tire spin...so i dont get tirespin at the RPM range..try it out if not fiddle around w/ it...cuz on some cars u have to rev a lil higher to reduce stalling.. BUMP for u
Old Jan 2, 2005 | 02:47 AM
yeegsr's Avatar
Default Re: how do you manipulate clutch and gas pedal for 1st gear drag? (DC2 BoZz)
b
BUMP for more reading and techinque
Old Jan 2, 2005 | 02:58 AM
DC2 BoZz's Avatar
do u know where i got that from...i'll tell ya..i was on flowmaster.com,and i was buying an exhaust for my stang and they have lil previews of what it sounds like..so it sed 2500 rpm and poppd the clutch and all u herd was a chirp and he was out..so i got in my teg and tryd' it...and by golly gee it worked...LSD ROCKS!!!!!!!!!
Old Jan 2, 2005 | 03:19 AM
Eclypz's Avatar
I like to slip the clutch
i rev up to 4K, hold the gas there and start releasing the clutch pedal just enough to break a little traction.....if it skids too much, then i slow down the release, and vice-versa.
when the clutch pedal is all the way up, then i plant the throttle.
Old Jan 2, 2005 | 03:41 AM
91TegLS's Avatar
Default Re: (Eclypz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclypz &raquo;</TD></TR><TR><TD CLASS="quote">I like to slip the clutch
when the clutch pedal is all the way up, then i plant the throttle.</TD></TR></TABLE>
That's the better way to do it. Popping the clutch is not good for the drivetrain and is actually slower than slipping it a little. I wish I had LSD though, because I dumped it at around 1800 once to see what it'd do and it just wheel hopped like a bastard and didn't really go anywhere.
Old Jan 2, 2005 | 05:15 AM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: (91TegLS)
I feather out the clutch on my GSR from around 4200rpms. I didn't have any wheelspin surprisingly. I am not a fan of popping the clutch, it usually leads to wheelspin, at least with my car having an open-differential.
Old Jan 2, 2005 | 07:52 AM
The Poopsmith's Avatar
Default Re: (JDMThoughts)
rev to your VTEC engaugement point and moderate the clutch and gas. keep the clutch right underneath the engaugement point when your staging
Old Jan 2, 2005 | 01:23 PM
DC2 BoZz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMThoughts &raquo;</TD></TR><TR><TD CLASS="quote">I feather out the clutch on my GSR from around 4200rpms. I didn't have any wheelspin surprisingly. I am not a fan of popping the clutch, it usually leads to wheelspin, at least with my car having an open-differential.</TD></TR></TABLE>
i think everyone should invest in LSD for the drag strip...and i am surprised that u dont burnout w/ an open diff...wow lucky u..and i have axels that can w/ stand 500 whp..so i think i am good..lol BUMP for all ur methods
Old Jan 2, 2005 | 09:58 PM
yeegsr's Avatar
this is the reason why we buy new clutch kits every now and then. At least faster then the usual clutch's life, but it all good
Old Jan 5, 2005 | 01:13 PM
Default Re: (DC2 BoZz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 BoZz &raquo;</TD></TR><TR><TD CLASS="quote">
i think everyone should invest in LSD for the drag strip...and i am surprised that u dont burnout w/ an open diff...wow lucky u..and i have axels that can w/ stand 500 whp..so i think i am good..lol BUMP for all ur methods </TD></TR></TABLE>
I only do a slight burnout, just a quick spin, both wheels spin freely which is weird considering I don't have a diff, but they both spin the same amount. Whenever I do a burnout there is always 2 black marks. Stock axles can support the power I am making.
Old Jan 9, 2005 | 09:03 PM
yeegsr's Avatar
ttt
Old Jan 10, 2005 | 05:49 AM
Nekekami's Avatar
Default Re: (yeegsr)
Thats pretty much how I do it too, depending on track temp I change the rpms, as far as burnout, unless your wearing slicks dont drive through the waterbox, even after the burnout water'll still be hanging around inside the tread of your tire and once you stop it'll run its way down your tire before you launch, kinda self defeating. Even without the burnout I've still 60 ft times in the 2.0 range at 40 degrees outside and moisture condensing on the track using the above method
Old Jan 10, 2005 | 05:53 AM
MikeTV
Guest
Posts: n/a
Exactly.......this is the best way to take off. it is the easiest on your tranny, and it is also the quickest way to get off of the line. and 4k is about the right rpm to drop it I have sh*tloads of weight reduction done, however, so I drop between 3k and 3500.
ac_attak
Sep 5, 2008 09:53 AM
eMpAtHy
Oct 14, 2004 11:31 PM
noodles806
Jul 23, 2003 12:58 PM
CaMiKaZi
Mar 31, 2003 04:18 AM
MrBite
Dec 11, 2001 04:34 AM
