vtec help
Old Jan 7, 2002 | 05:53 PM
b18c-93's Avatar
New User
Default vtec help
does the oil pressure switch have too be plugged in the one on the block in order for the vtec too work because i am getting a code 21 not the vtec oil pressure switch. vtec works untill my check engine light comes on
Old Jan 7, 2002 | 05:54 PM
Jared's Avatar
Default Re: vtec help (93gsb16a)
code 21 is the code for a faulty VTEC solenoid.
Old Jan 8, 2002 | 09:14 AM
GM2000ITR's Avatar
New User
Remove the VTEC solenoid and clean the oil screen out thoroughly (brake cleaner perhaps). If the rubber gasket surrounding the screen is dry/cracking, you will need to replace it completely (not too much $$$). Good luck!!
Old Jan 8, 2002 | 12:37 PM
Katman's Avatar
hrmm..
what ECU are you running?
your statement is unclear.....
you should have everything plugged in on the vtec solenoid (green plug & grey plug) in order for VTEC to work (along with the VSS & coolant temp sensor)..
94wip
12
Jun 20, 2024 07:23 PM
dkboyny11
Jun 2, 2005 03:45 PM
danteisme
Sep 26, 2004 03:19 PM
turbo2gteg
Jul 23, 2003 06:15 AM
