Results on stuck injector.
i am not too familar with itrs, but make sure if your original obd2 injectors are saturated ones, install a resistor box if you want to use peak hold injectors. Not sure if the obd1 injectors are peak hold or not, cuz like i said i am not to big on ITRs or b-series in general so i dont know the specs. but yeah sounded like you just swapped the injector clips and poped them in. if you run peak hold injectors w/o a resistor box you risk frying your ecu.
Sassafrass
Oct 9, 2004 09:58 PM
racerxadam
Feb 19, 2002 09:00 PM
oops
