Procedure for oil pan gasket.
Old Jan 1, 2005 | 03:51 PM
blackdelslo's Avatar
Default Procedure for oil pan gasket.
Replaced my oil pump on h22, put oil pan back on, didnt put enough honda bond on driver side, all of the oil spills onto the ground This time i cleaned off all of the residue and put it on like toothpaste and im going to wait about a day and a half. Am i doing this right? Service manual doesnt say how to apply hondabond on the oil pan gasket.
btw i only put it on the bottom of the gasket and just a thin layer on the gasket to block side. How long should I wait before i drive the car?
Old Jan 1, 2005 | 05:24 PM
Altilude's Avatar
Default Re: Procedure for oil pan gasket. (delLudeVTEC)
there is a torque sequence as well starting from the center moving outwards, with a torque of 9ft Lbs, - also the helm's I have doesn't call for hondabond - just says to put some liquid gasket at the edges of the passenger side - where it dips.
Old Jan 1, 2005 | 07:23 PM
98TypeSH's Avatar
Default Re: Procedure for oil pan gasket. (Altilude)
and what exactly do you think hondabond is ?? (liquid gasket)
If you put to much of it on, there is a good chance it may flake off on the inside of the pan and get caught in your oil pick-ups and cause oil starvation.
Old Jan 1, 2005 | 11:18 PM
Default Re: Procedure for oil pan gasket. (98TypeSH)
Sorry, i meant I put the pan on, and then waited a day and half before putting oil in it. I wanted to let it harden.
Old Jan 3, 2005 | 06:12 PM
djbrandonr's Avatar
I used a cheap sealer one time and caked it on, and for the longest time afterward vtec wsnt hitting as good as it used too, like it was someway restricted. So my tech now was fixing most of my leaks pulled the pan off and all the excess flaked off in the pan and made a big clog in one of the lines. But once all said and done he just used the honda gasket w/ no sealant and nothing leaks and vtec hits like normal again.
Old Jan 3, 2005 | 07:35 PM
prylwd's Avatar
I am pretty sure you are not supposed to put a lot on. Just get a new seal, use a little bead of HB, and tourqe in the proper sequence.
hondaman211
Jul 22, 2020 06:29 AM
miro_gt
Jun 24, 2007 08:02 AM
ITR-00-1457
Apr 11, 2005 06:26 PM
ringgold
18
Sep 20, 2004 04:28 AM
IntegraB18A
Dec 20, 2003 08:18 PM
